Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Air con
Porsche 996 c4s Air con getting no power.
When you push button Fans don't come on nor does compressor
All four relays ok
fuses D6/C7/E7/C10 ALL OK
Compressor ok when jumped with live wire,
Temperature unit you press for air con ok as swapped with other car.
Is there some sort of sensor stooping it coming on ? .Because when press air con button no power goes to four relays or compressor relays as no clicks when put fingers on them
Old 02-08-2018, 07:26 AM
JFP in PA's Avatar
There are two: Low/high gas pressure switch and a thermal override switch.
Accrochez-vous bien de vos rÍves..........."
Old 02-08-2018, 08:12 AM
Do you know where they are and is there anyway to test them ,Thanks
Old 02-08-2018, 08:22 AM
JFP in PA's Avatar
Before fussing with the sensor switches, have you tested the systems pressures? If the gas pressure is either too low or too high, the sensors will never let the system run.
Old 02-08-2018, 08:54 AM
Hi
The pressure should be right as i had to new condensers and a dryer three years ago,Anyway went to have it topped up but they could not re gas as the machine said there was a problem with the system.I assumed the problem was because compressor wont turn on because some sort off sensor stopping it
Old 02-08-2018, 10:22 AM
JFP in PA's Avatar
I still would not be pulling out sensors until I knew what the actual pressure is; by far, most non run situations we see are due to low gas.
Old 02-08-2018, 10:53 AM
Air con
Hi
Had the pressures checked and all ok,But still not working
Old 02-14-2018, 05:36 AM
JFP in PA's Avatar
Originally Posted by porschedavid View Post
Hi
Then you need to get ahold of a factory service manual and start diagnostics on the sensors.
Old 02-14-2018, 07:50 AM
