-   Porsche 996/997/991 Forum (http://forums.pelicanparts.com/porsche-996-997-991-forum/)
-   -   P0456 Check Engine Light -08 C4 Cabriolet (http://forums.pelicanparts.com/porsche-996-997-991-forum/989393-p0456-check-engine-light-08-c4-cabriolet.html)
Jimbowne 03-03-2018 03:05 PM
Hello all,
I recently purchased my first 911: a 2008 C4 Cabriolet. About two weeks after purchase, my check engine light came on and the error code os P0456. From what I've read so far this seems pretty benign with likely cu'prit being my fuel cap or a vent valve. Does anyone have any experience with this fault? I'm going to try replacing the gas cap first; is that a good start?
Regards,
Jim
tonythetarga 03-05-2018 08:57 AM
Check the O ring on the cap for cracks. Car is now 10 years old. Could be any part of the evap system. If O ring is good you might be better off having a better diagnosis then continuing to swap parts until you find the right one.
Jimbowne 03-08-2018 02:11 PM
Thank you Tony. I just replaced the gas cap and the light remained on. I may try disconnecting the battery terminals in case it's a latched fault. If that doesn't work I'll probably take it to a shop and have them isolate it.
JFP in PA 03-08-2018 03:40 PM
If you did that and brought it to my shop, we would charge you extra diagnostics time to compensate for the data lost when you disconnected the battery...................
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
