Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
P0456 Check Engine Light -08 C4 Cabriolet
Hello all,
I recently purchased my first 911: a 2008 C4 Cabriolet. About two weeks after purchase, my check engine light came on and the error code os P0456. From what I've read so far this seems pretty benign with likely cu'prit being my fuel cap or a vent valve. Does anyone have any experience with this fault? I'm going to try replacing the gas cap first; is that a good start?
Regards,
Jim
Old 03-03-2018, 02:05 PM
Check the O ring on the cap for cracks. Car is now 10 years old. Could be any part of the evap system. If O ring is good you might be better off having a better diagnosis then continuing to swap parts until you find the right one.
Tony G.
2006 Cayman S
1986 911 Carrera track car...gone but still loved!
Remember Warren Hall. Contact me for your Warren 'Early S Man' Hall memorial decals.
Old 03-05-2018, 07:57 AM
Thank you Tony. I just replaced the gas cap and the light remained on. I may try disconnecting the battery terminals in case it's a latched fault. If that doesn't work I'll probably take it to a shop and have them isolate it.
Old 03-08-2018, 01:11 PM
JFP in PA's Avatar
If you did that and brought it to my shop, we would charge you extra diagnostics time to compensate for the data lost when you disconnected the battery...................
Accrochez-vous bien de vos rÍves..........."
Old 03-08-2018, 02:40 PM
