Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
Newbie 996 questions
I am a new 40th anniversary 996 owner, and just had a couple of questions. When starting up these cars, do the starters normally seem to turn over slower than any other cars out there? Mine seems "weak" in a way, but this may be normal. The battery gauge is fine - it's above 12V.
The second question comes to stalling - if you stall one of these cars, is it normal to hear a "clank" type of noise when you restart it?
Thanks,
Old 07-08-2009, 10:07 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
RKC RKC is offline
My 2007 starts way slower and longer than my old 87. And, having not stalled a car in 25 years, I have stalled the new to me 997 twice in the past few weeks....must be used to the old 911 - owned it almost 10 years.
I don't know about a "clank" sound, but if the motor doesn't crank long enough to start on the first try, there is some funny "clank" like sound - like a whole bunch of electronics being upset and making adjustments. I've learned to crank it a little longer than the old air-cooled cars.
'07 997 Targa 4S Lapis Blue
'07 BMW X5
'87 Targa Guards Red (gone, but not forgotten)
Old 07-08-2009, 12:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
FPB111's Avatar
The "clank" may be your dual mass flywheel. The pressure plate bolted to the flywheel has a separate piece that contacts the clutch disk. That piece can turn up to 5 or 15?? degrees. The "clank" is pretty common. When you replace the clutch there is a simple procedure to check the flywheel.
There is a debate about changing to a Light Weight Flywheel (LWFW) and spring centered clutch similar to the older air-cooled cars. Join Renntech.org and or Rennlist and search there. Lots of info for 996 and later.
1972 RS 3.2 twin plug short stroke crank fire, roll bar, camber truss, factory short shift, turbo brakes sadly sold
2003 996 cab 6 speed happily bought
Frank
Old 07-16-2009, 07:40 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
