1999 Porsche 996 does not start
Went to start the car. Turn the key, the instrument panel lights and gauges come on, but the car will not start. No click, no sign of starter activity. Tried to roll start down the driveway, but that did not work either.
43K miles, drove fine and parked in the garage last week. Battery was checked - full 12+ volt charge. Checked 25, 15 and 10 amp fuses in the panel but did not find any blown fuses. Questions: What should I check next? Is there a starter solenoid to check? Is there another fuse box in the engine compartment? Thanks in advance. Don Metzler Louisville, CO |
To follow up - I put the key in and turn it to on. The voltage reads just shy of 12v. When I turn the key to start, the voltage does not drop.
check grounds
Manual tranny?
is the clutch interlock switch good? this got me, sister drove the car and the carpet slid up behind the pedal! she couldn't push the clutch all the way down:-) |
Yes - manual transmission. I thought of that, but I hear the click when I press the clutch in, so I presume that is okay.
How do I check the grounds? I am in need of a repair manual. |
Bad ignition switch? they are known to fail. Can't recall the symptoms. I imagine search could be your friend.
1987 944 Past: 2000 Boxster 2.7, 1978 911SC Euro, 1976 914 2.0, 1970 914 w/2056 |
You can try to "bridge" the ground to see if that's the problem. Use a jumper cable (or maybe two of them if not long enough).............and connect the negative of the battery terminal to somewhere on the transmission case close to the starter. If the car starts, then there is most likely a grounding problem.
We tried this setup previously on a car (not a Porsche) and were able to find a bad ground strap going from the body to the engine. Good luck! |
Also, to check your ignition switch........try starting the car using an external remote starter. Be careful since the remote starter will bypass the clutch safety switch. Make sure the car is out of gear and everything is safe before starting! Remember............Safety First!!
By pass the clutch switch, it's the most common problem, ignition switch failure gives different symptoms.
Just try moving the clutch pedal about as you turn the key. Batteries last about 4 years, how old is yours?
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
My first guess would be clutch switch. then check the connections on your immobilizer under your seat, maybe unplug and plug back in. Have seen this exact problem a couple times.
Think you've ruled out battery... ignition switch has different symptoms.
Eric 3.6L Boxster GT Race Car, POC GT3 class www.hrgruppe.com www.facebook.com/hrgruppe |
Did you ever figure out your starting problem? Inquiring minds would like to know!
Hey guys, ive been reading some of your suggestions and im having the same problem. I purchased a porsche 911 996 year 2000 I dont have the remote control only was given the key. Im having problems starting the vehicle, I have power to the starter and I hear the click of the carborator opening and clicking but wont fire up to start the engine. At first i thought I had no spark going to the coils, but I do have spark. Ive checked the grounds they seem to be okay, as well as the clutch.
Ive tried turning with the key no luck, I manually tried to start the solenoid it tries to turn over but wont ignite. Do you think I need to demobilize the alarm perhaps to get it to start, or is there a reset on the DME i might have to take off the switch and plug it back in. Something is telling it not to fire...any possible suggestions guys...im REALLY STUCK. Thanx Gavin |
to follow up- My air bags where deployed do you think this could be a problem?
Old Member
A fully charged battery is closer to 12.8v and anything less can give you plenty of starting problems. Charge the battery for a couple of days just to be sure, it cost you nothing and it's the easiest thing to do. |
