Parts Catalog Accessories Catalog Tech Info Tech Forums
  Search our site:
 Cart  | Project List | Order Status | Help
2000 996 Stereo/Nav Removal & Replacement
I have a 2000 996 Carrera coupe, and it has a AM/FM/Cassette/Nav unit in the dash, with an amp and CD changer in the trunk, and 6 speakers. There is also a separate nav system CD drive in the dash just below the Nav LCD display for reading only Nav data CDs. Well, my stereo is malfunctioning...switches in the head for controlling changing presets don't work. The unit turns on and off but there is no sound and none of the buttons work, and I can't even select the CD changer to listen to CDs. So, since I never use the Nav system, I'm thinking of totally removing the stereo and Nav and Nav CD and putting in a new aftermarket AM/FM/CD player without Nav. Will the old amp and CD changer work with a new stereo unit? How do I remove the stereo and Nav CD from the dash? What will happen to the climate control system since its performance will no longer be able to be monitored on the Nav LCD display? (I never look at it there anyway). Will it hurt the car's other electronic systems if I remove the old stereo and Nav CD and replace it with something newer but without Nav? What stereo do you recommend? How do I cover up the big hole left when I remove the old Nav/Stereo LCD display? (I assume the new AM/FM/CD will go where the old Nav CD reader is, just below the Nav LCD display.) Do I need any special tools?
Old 04-09-2011, 10:06 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Replacing the NAV on a 99 will not impact any other electronics and will work with your amp and speakers. The easiest bet would be to replace your stock unit with a double din aftermarket unit. If you pry the horseshoe trim (upside down U trim) above your radio that stores all of the switches, you will see the sides of the nav with two tabs that need to be pushed in to unlock the unit which will allow it to slide out.
You can pick up a double din face plate mounting kit and replacement cubby hole for your nav so it looks factory. Do a search on google for replacing the stereo on a 99 996 and you will get some hits with technical details. I just replaced mine last week but included new speakers and amps - sounds incredible.
You may also want to contact Car Audio Innovations or do a search for them on the 911 forum - they work on Porsches and have pretty good solutions.
Old 04-18-2011, 04:16 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
