How Common is IMS/RMS failure???
Seems like I'm finding a ton of info warning about IMS/RMS failure and I was wondering if anyone really knew how common of an issue it is? It seems like everywhere you look on the web people are talking about it but then I've found Totall911.com articles which speculate its only about 5% of the cars made.
Thoughts? |
In the last 19 months I have seen 9 of them. One of them had the cam deviation chatter.
5%.
Of 145,000 M96 996's... 7,250 failures. Ref. The Truth June issue GT Porsche. |
IMS and RMS are two entirely different issues and they should not be discussed in the same context.
IMS = Intermediate Shaft RMS = Rear Main Seal The RMS issue is a leaking seal, nothing more. It's actually quite rare to find a car with a leaking RMS these days - most leaking seals have been replaced with the latest version which doesn't leak. Those motors which could not be fixed because they were out of spec were replaced by Porsche under warranty. RMS issues are easy to spot and the issue is harmless, except maybe a spot of oil on the garage floor. The IMS though is a different story. (OK - IMS seal leaks can occur, but like the RMS these are harmless and easy to fix.) IMS *bearing* failures are a real problem. The bearing that supports the intermediate shaft was poorly designed and prone to failure. It gives little to no warning before it fails and when it does fail it destroys your motor. Dead, done - you're not rebuilding the old motor because it's fu^%ed. You're buying a new motor. This has been discussed to death on line, and then discussed a zillion times more. In the end though, the answer is always the same, only Porsche knows, and they probably don't even know, and at any rate they are *not* saying anything. Problem is that Porsche replaced a lot of engines in the first five years or so, all under warranty. Not all of them were IMS issues, some were RMS issues that could not be solved, some were for cracked heads, some were for porous castings, some were just service manager's taking the easy route to making a customer happy. Porsche took all of the motors back for analysis. most were re-manufactured with upgrades and these went back into the system. These days we rely on the experience of knowledgeable independent repair people, but they only see cars with problems so they have a biased view. After all the chatter is done, a figure of between 1% and 5% seems to be consensus, with the later 3.6 litre cars suffering less than the early 3.4 litre cars, and with early Boxsters being the worst....depending on who you talk to because of course there were a lot more Boxsters sold, so in absolute terms there will also be more failures. Now don't ask again because M96 owners get annoyed by the question. ![]()
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete. 2002 996 - no PSM - yes it was real Porsche 78 SC - 3.0-weber-msd - gone - it was fast |
I've got an impression that the failure rate is much higher. But you are right, independent repair people are like doctors, they only see sick patients.
As a PS one of my customers with an 02 boxster bought a crate motor 2.5 years ago (35k) because of an IMS failure; this time I did an oil change and found the filter full of metal. And to add insult to injury, I checked PET about two weeks ago and the prices of the early engines doubled from 9k to 18k. This will really total a lot of the early cars as the cost of repair will be two to three times value of the car. |
Jasper covered it in a nutshell. I've seriously considered a 996 - it's a lot of car for the money. Three hundred HP, rear engined goodness for 17-20K! But, all you need is for the engine to conk on you and you're instantly upside down - on a car that still depreciating. I'm still tempted...
Kurt S 1984 911 Carrera |
IMS on 997.1
To what extent is IMS failure a concern on the 997.1? Just bought a 2006 with a M97.01 motor and wasn't aware of this issue until now.
Check out "total911.com" and scroll down to "997 engine failure: fact or myth" 1999 thru 2008 models are mentioned
Kurt S 1984 911 Carrera Last edited by KNS; 09-01-2011 at 07:28 PM.. |
Well that was a long and depressing read. I just have to hope that I'm not one of the "unlucky" ones.
I would drive the piss out of it and not stress over it. If it's gonna fail - it'll fail no matter what you do.
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
Honestly said : the 996 is a great car. IMS can be replaced it's not alien tech or un obtanium. The RMS if it does go, does suck but it all depends on why. Most 911's of any vintage that have problems tend to be heaps due to deferred maintenance.
Sure like all things mechanical they have soft spots. But if you want a nice machine not über Spartan the 996 in my opinion is what I call the 911 for everyone. Where I'd say on earlier machines you need to be a special breed for such cars. The 996's are a lot of fun, comfortable too. Like anything take your time and go thru a number of cars vs the first thing that comes a long, records are nice but not always indicators of a well kept machine. |
When you buy, budget $1000 to have the LN IMSB installed. Intermediate Shaft IMS Upgrade and Retrofit Kit for Porsche 911, Boxster, and Cayman models
1972 RS 3.2 twin plug short stroke crank fire, roll bar, camber truss, factory short shift, turbo brakes sadly sold 2003 996 cab 6 speed happily bought DE instructor since 1985 Frank |
Boxster IMS & RMS failure
I recently lost my clutch in my 2000 986 with 60,000 miles.
Upon inspection, Porsche reported that I also had an IMS & a RMS leak, that needed to be addressed immediately. Total cost for all three issues.....$2400.00 It's not purchasing these amazing vehicles, it's the price of maintenance. While they may be some of the most reliable vehicles on the road, when they need service, they are not cheap to repair. |
This is why preventative maintenance is critical. If your cost includes a new IMS bearing you are doing fine. |
1988 944 2.5L 8-v NA 260k
$2,400 for parts & labor on IMS, RMS and Clutch sounds like a deal.. 944 clutches alone (P&L) can cost nearly that when not DIY. Also, $2,400 is like what 4 car payments.. ? ![]() Worth it for such a fine ride.
'88 8v n/a 260k with 32k on current TBelt M454 M533 M650 M425 M418 New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
$2400 is not a lot of money for a clutch replacement no matter what you drive.
FWIW I just installed a clutch, flywheel, RS motor mounts, air oil seperator and clutch slave in my car. Parts cost me $2600, but I used a sport clutch which costs more. If I would have done the bare minimum OEM clutch and new RMW plus a IMS flange (no new bearing no flywheel no AOS no clutch slave) it would have cost $800 in parts. $650 for the clutch kit, 150 for the seals.
I've been looking at 996s
And noticed if I used the search refine ( milage highest >) I found a bunch of Cars with 100 k plus and no Replaced engines |
There was even a guy here (or maybe it was rennlist) who aked if heshould avoid a car *because* it had a new motor. The absence of an advertised new motor doesn't mean much. The presence of an advertised ne motor does.
Higher mileage care have less of a chance of a failure. Change oil every 5K miles on daily drivers or every 6 months on a garage queen. Keep the oil level to the top of the stick.
The numbers I read said "10% of the 996 engine failures were IMS related" not 5 to 10% of all 996's. I read somewhere that alot of the actual IMS failures had one thing in common, poor maintenance, low oil levels and filthy oil. My opinion, take care of your car, don't drive it like you stole it, after all you didn't steal it and if it granades its on your dime and keep an eye on the dip stick. If the IMS bearing lost its inner seal and the ball bearings are exposed inside the engine it is crucial that the oil level is not low so the bearing get lubricated by the motor oil. My 996 could pass for showroom brand new, I'd rate it a 9.9 out of 10 and it has 70+K miles. I drive it daily and only use Mobile 1 0w40. The car runs it's coolest with that grade, I've tried 5W40, 10W40 and 15W50, the temp gauge is cooking hot unless its 0W40. |
