Parts Catalog Accessories Catalog Tech Info Tech Forums
  Search our site:
 Cart  | Project List | Order Status | Help
  We salute a legendary member of the community.
Thank you for selflessly sharing your wisdom with us...
Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997 Forum
New Owner Needs Maintenance Advice w/ pic
I just sold my 88 Targa and purchased this 04 C4S with 24,300 miles, and need some advice about maintenance. Maintenance records are sketchy at best. Looks like oil changes were done and one brake fluid change was done about 4 years ago at 16,000 miles. It also looks like most things were checked like brake pads and fluid levels, and but I can't find much else being changed. The car is in great shape and runs perfectly. I need to figure what is needed to get maintenance up to date. Here what I had on my list to do right away:
Brake fluid change - dot 4
Air filter change
Here is what I am not so sure about:
Hydraulic Clutch fluid? (Clutch seems just a bit stiff but works fine.)
Coolant?
Spark plugs (with so little miles not sure this is needed)
Am I missing anything? Appreciate all advice. Thanks!
JPL
2004 C4S
Old 04-24-2012, 03:50 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
one of gods prototypes
bell's Avatar
spark plugs aren't until 30k, but wouldn't hurt to change them if they re original........
check the cabin and engine air filters
clean out the water drains in the battery tray area (use compressed air not a ,.and more importantly the rear drains, remove the rear speakers (just 2 screws on the grills) and the drain is behind them....if these clog it'll fill the floor with water in the rain and destroy the alarm brain.....actuators...etc....
it looks pretty clean and unmolested, so every thing will probably check out ok...
I would also change the gear oil
do a fresh brake flush
bring it up to temp with the a/c off and make sure the low speed fans come on...drive it good then let idle and they should kick on, you'll be waiting 30 minutes if it just idles to reach temp.
I wouldn't mess with the clutch hydraulics unless the pedal isn't coming up
coolant flush, wouldn't be a bad idea, use the porsche coolant, mix it accordingly for your climate.
kinda rambling lol but I work on allot of 996s lol
Old 04-24-2012, 05:19 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
OK, lots of good suggestions. Thanks.
JPL
2004 C4S
Old 04-24-2012, 05:27 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
FPB111's Avatar
This site has a very active 996 section
http://forums.rennlist.com/rennforums/996-forum-60/
1972 RS 3.2 twin plug short stroke crank fire, roll bar, camber truss, factory short shift, turbo brakes sadly sold
2003 996 cab 6 speed happily bought
DE instructor since 1985
Frank
Old 04-24-2012, 07:42 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
