Parts Catalog Accessories Catalog Tech Info Tech Forums
  Search our site:
 Cart  | Project List | Order Status | Help
  We salute a legendary member of the community.
Thank you for selflessly sharing your wisdom with us...
Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 996/997 Forum
Question 996 leak-down test
I'm trying to do a leak-down test on my 996. On my '71S it was easy to find TDC for each cyl by following the valve adj procedure, rotating the crank& pulley 120d. I see what may be a TDC mark on the 996 pulley but ?? I know about holding a stick in cyl, etc but that seems the hard way esp alone without a long third arm... and an eye on a stalk. Also, how does one remove the rear valence? Where are all the screws? Are there any hidden? It is prob easier with the cats & cans off, huh? tnx, jvm
JVictor
Old 05-18-2012, 03:59 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
TDC on the pulley is thru the pear shaped hole into the case hole at !0:00- 11:00 with a 5/16" allen wrench if you don't have the tool in the pic. This lines up the pulley mark & TDC arrow on the case @ 2:00 on the case for TDC cyl.1 & cyl. 4
Old 05-18-2012, 05:50 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Hey OC, Thanks so much! I'm in to it again tomorrow. jvm
JVictor
Old 05-18-2012, 09:14 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
one of gods prototypes
bell's Avatar
also......leave the exhaust on....just jack up the rear to a good height..
first wiggle the rubber cover up of the connector for the coils (will make plugging the coils back in easier...trust me)....then unplug coils....
find a small ratchet with a good 5mm allen and pull coils....
when pulling the plugs I like to use 2 short extensions as it gets tight when you pull them out with the mufflers in place....
follow the previous post to tdc each cylinder.....
Old 05-19-2012, 04:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
