Anyone Michelin TB-5 tires on the track?
Hi
I was wondering if anyone has run these tires and how do they compare to something like the TD-S Hoosier or the new TD-R if anyone has tried that??
www.machine-motorsports.com 1971 911T 3.2 1971 911S 2.5 1972 911S 2.8 1972 911T 2.7 1965 911 300760 1976 911S |
Michelin TB 5.
Hello.
I run with the Michelin TB5 on my race car. Class rules state that we must run with street approved tires in the 1971-class. https://youtu.be/MHtYiZxvP48 Let me know what you need. Thanks - Olsen911 - Tommy Olsen
“I will not demonstrate it, I will race it.” Juan Manuel Fangio |
What tire pressures (hot) are you running? Have you figured out what camber settings that works best, do they like a lot or less?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Michelin TB-5
Hello Magnus.
We start out with 1.5 BAR / 21.75 PSI on fronts and 1.4 BAR / 20.30 PSI on rears and see about 2 BAR / 29.00 on both at the end of the session - 15 minutes + 1 lap. We run 1.5° on fronts and about 2° on rears and the car handles well. Thanks - Olsen911 - Tommy Olsen
I have a lot more camber, I think its ok in the front but in the rear I'll try 2°.
Coming back to this...thanks for the info. I would have thought they would need a little more cold pressure. Have you ever run the Avons Or Hoosier TD-R? do you think the TB5 is superior?
bumping this...I'm torn between these and the Hoosier TD-R tires. Anyone run both. If not what has the TB-5 performed like?
