A racecar is a racecar is a racecar . . . . . .
As you know, we glued our lug nuts on with weatherstrip adhesive for green flag pit stops. Lug nuts were 1" and used a special socket that allows engaging with the gun at full speed, with a spring to push out the lug nut. Teams could use double ended lug nuts (the tapered cone on both sides) to eliminate the chance of putting it on backward. But this will all become a moot point as nascar said they will switch to one big nut for wheel attachment this year. |
Yes. Way back when it was ARP, then gradually migrated to MSI.
Dan - since all I "know" about NASCAR is pretty much limited to TV commentators, I appreciate your contributions here. I've tried to find NASCAR's rules on line, but haven't been able to. Working with PCA's Club Racing rules has me always a bit curious about other series (especially professional ones) with regard to safety rules.
I have wondered how glued nuts would work, but elastic weatherstrip adhesive answers that? Stretches enough to keep the nut on the bullet ended stud? But center locks in NASCAR? First EFI, then this? What's next - IRS (like every production sedan nowadays)? |
On the newer (996+) Porsches with wheel bolts with an integrated kone-washer the lube should be applied between the the washer and bolt.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. Just works! 911T Coupe -69, 3.6, G50, "RSR", track day. Sorting out issues... 924 -79 rat roddy... 931 -79 under total restoration... |
Porsche TSB:
![]() Name change: Optimoly HT equivalent ? ![]() A close facsimile seems to be Permatex Copper Anti-Seize. Sherwood |
Racer
Except that Permatex Copper Anti-Seize is a grease and certainly changes the torque requirements and Permatex specifically states in their Copper Anti-Seize TDS that it is not for use on lug nut or stud applications.
So, other than that, sure, it's a close facsimile..... ![]() P.S. I have a hard time believing that the Optimoly HT or its replacement does not affect torque requirements regardless of what Porsche says in that bulletin.
Scott Winders PCA GT-3R #3 Last edited by winders; 02-26-2021 at 12:27 PM.. |
Thread Tools | |
Rate This Thread | |
