Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Tim L's Avatar
PCA club race rule on wheel size
I would like to race f stock with a 84 911.
My question is what is the widest wheel allowed and still be stock.
Tim
Old 05-28-2003, 12:42 PM
CRNT918's Avatar
According to the rule book, you are allowed 1 inch wider than stock.
On your car that should be 7's in the front and 8's in the rear. You should be able to fit 225's in the front and 245's in the rear.
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 06-01-2003, 06:36 PM
Tim, Look in the owners manual for your car and see what the widest wheels that came with the car. You might find they offered 15 inch wheels in 7's and 8's( that was the case with the Carrera). if that's the case you will be able to run 8's and 9's( that's what I run in F stock).
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 06-03-2003, 12:23 PM
Tim L's Avatar
James
I have an 84 Carrera and it came stock with 6's and 7's but it does list 7's and 8's x 15 so I can use 8's and 9's.
Tim
Old 06-03-2003, 12:38 PM
Yes!! That will help a bunch. Just so you know you will have to do some "modification" to the tub in the rear with a 5lb dead blow if you run alot of neg. camber. No biggie though. Also, you might have to do some more in the front too. Every car is different so my suggestion would be to bring the hammer to the track so when you hear some rubbing you can fix the problem.
Cheers, James
Ayrton Senna
1993 964 RS
Old 06-03-2003, 01:17 PM
