Hot Lap Timer
What side of the car do you mount the electronic 'eye' part of the Hot Lap timer? I've seen it on the passenger side on most cars. I don't have the tri pod that you would normally set up on the start/finish line. There is usually someone that has one set up but I would like to know the most common side to mount and what height should I set it at.
Thanks, |
It will always be different at different tracks. Usually, for me, it's on the driver's side. You can usually figure it out if you know the layout of the facility. Most tracks won't let anyone walk across the track to set the sender up, so they're usually near start/finish on the side of the track accessible from the paddock.
Bring lots of zip-ties and a little soft foam insulation to make mounting the receiver (and re-positioning it) simple. |
Thanks Jack. As always you're a great help. Hey, I would like to join you guys sometime at WSIR. I only have 1 time trial, a few autocross's and DE's under my belt. What's required to race with you guys.
Thanks, |
John
It depends on the group. Open Track Racing is one that's very good (and cheap) that's a good choice if you can get a weekday off. Other than that, Speedventures, NASA, Alfa ROmeo Club, Tracquest, and the POC are all good, although prices and track time will vary. I don't think I'll be there, but Open Track Racing has a day coming up on October 8th. It's only $125 for the day, and you'll get 2 1/2 hours of track time. They also have instructors available to help familiarize yourself with the track. I may be doing a big Willow weekend November 8th and 9th with Touring Car Racing Association, which is also a pretty good group. |
There was a C2 at Irwindale last weekend with plates that said "Schubee" on it- was that you? TT |
ttweed...that was I.
Were you there? It was my first time in the C2. That was a blast even though my car wasn't set up right. The Yoko's I have on isn't the best for the track. I tried adjusting the tire pressure but that didn't help. I haven't installed my RS swaybars and stiffer coil overs either. I'll be working on that in the next few days before the next outing. Hey, were you hanging with Zimmerman and Jim Planet? I noticed a few R Gruppe guys over there. Come to think of it, you had the trailor and the F-250 towing it, right? Wait, were you the guy collecting all the awards for everyone? Next time I'll make sure to stop by and say hi. I could have used some help setting up my car for that autocross. Cya... |
Irwindale AX
Mike won TTOD in his white '73 911 and waxed me in AM class because I didn't put on my slicks and he did. I had 4th TTOD in my silver '73 (#908), missing 3rd by .022 (yes, that is 22 one-thousandths of a second- I musta blinked at the wrong time!) and missing second by 2 tenths. I hate it when that happens. You end up kicking yourself for that tiny little mistake that cost you a half second. I know I blew that much getting loose coming off the banking into the chicane towards the end. I wish we could have had more practice on that track, it was very interesting but a little too tight in the beginning through the infield for my car, especially without the slicks. TT ps- BTW, the hotlap transmitter was on the passenger side at this track, and if you come to a SDR autox, it will always be on that side at Qualcomm Stadium. |
TT
I told them about the description and all they said is as long as the class was correct, don't worry about it. I think the 944 turbo does fall in the KS/S class. However, I think I put myself in the wrong class 'cause the KS/S is for a stock 964. I have a few mods done, not much, that may have bumped me into another. I'll have to look into the rules again and make sure I'm in the right one. Yeah, my time sucked the big one. I was more interested in learning the car rather than worrying about getting a fast time. This was the first time I took this one to the track and the difference compared to the '81 I had was night and day. I think I'll do a couple more autox's before I take it on WSIR or any other big tracks. After I put on my sways and my other set of coil-overs, I think it'll handle better. Let alone getting some track shoes for the car. So as Jack mentioned above, I should take tons of zip ties and prepare to change the transponder from left to right depending on where the tri-pod is set. Or, I can just buy my own and have it set where ever I want it. |
Zip ties are the answer. You don't really want to leave it in the car when you're not using it. Somebody'll swipe it.
TT |
Ive left my pit stall "open" for years... and have NEVER lost a zip tie.... sucks that a few ruin it for some.. |
"......The more events I attend in other regions, the more I realize what a good performance driving program we have in San Diego region."
Yeah Tom, I must have said that 30 times that day..... btw Tom, next time - since you're part of the crew, park yer rig with all the rest of the 'gruppe rigs....;) that way I can partake of a few more of those killer chocolate chip cookies you make !!!!:D Sent my $$$ in for Pahrump Tues!!:D |
| All times are GMT -8. The time now is 11:56 PM. |
