Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Super Moderator
cstreit's Avatar
Batt in smugglers box... Where to mount fuel pump?
Guys,
I'm re-locating my battery to the smugglers box and deleting the battery boxes. I have a fuel cell and mounted the fuel pump in the smugglers box.
So now I'm not sure where to put it! The pump is kinda space taking because it's got an integrated pressure regulator and AN fittings on it.
Since the cell has top openings for the fuel line, I suppose I could just mount it right inside the front trunk, but I'd like something more elegant.
Ideas?
Chris
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-21-2004, 07:19 PM
From the AUTOMETRIX web site.
Joe Riley
84 Carrera Targa
69 911S Coupe
Click here for 911S project "updating as I go"
Old 01-21-2004, 07:57 PM
Super Moderator
cstreit's Avatar
Thanks Joe... Wouldn't be too hard since I'm running new fuel lines anyway. Anyone else?
Chris
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
Alcon Brake Kits
Old 01-21-2004, 09:47 PM
CRNT918's Avatar
Boy, is that pretty!
PCA-Chicago Region-DE Tech Coordinator-Retired
PCA-Chicago Region GingerMan DE Co-Chair-Retired
1987 Cab-under construction-Sold pending pickup
1986 911- Race/DE car-Sold
Old 01-22-2004, 08:15 PM
Super Moderator
cstreit's Avatar
Nuthin' like a powder coated Chassis eh?
Chris
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
Alcon Brake Kits
Old 01-22-2004, 10:20 PM
304065's Avatar
Chris,
Put one IN THE TANK. Get the "black box" from ATL (I know you have a fuel safe cell but this will work OK) -- which is a plastic cube about 6" on a side, with three flapper doors in the bottom and an integral Walbro GSS340 fuel pump. The pump is OEM in the Mitsu Diamond-Star cars, I think, and flow is adequate.
http://www.atlinc.com/racing/page16.htm
I would pull off the fill plate (watch those sparks), pull out a couple pieces of the foam and notch them so you can put the box on the floor of the cell. When you stuff the foam back into the cell, it should hold the black box in place. You will have to drill a 1/2" hole in the fill plate for the bulkhead fitting for the wires.
It works GREAT. NO starvation, high pressure and volume, and the best part is, those pumps are only $85 a piece, vs. the Bosch/Barry Grant types which can run several times that. Hell, you could carry a spare (I do).
You may have to plug the outlets from your cell if they are at the rear bottom where the factory outlets were-- I don't remember if you converted to top-fill or not.
And while you are in there, how about a dry-break?
More info on the pump/specs here:
http://www.autoperformanceengineering.com/
Fuel Starvation at Watkins Glen
'66 911 #304065 Irischgruen
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-23-2004, 10:13 AM
Super Moderator
cstreit's Avatar
John,
I run carbs and so only need 4 psi..
Nice setup though!
Chris
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
Alcon Brake Kits
Old 01-23-2004, 10:46 AM
scca_ita's Avatar
I thought it was best to mount the fuel pump as close to the fuel tank/cell as possible?
Old 01-24-2004, 12:52 PM
what? me worry?
TimT's Avatar
Chris do you have enough room to mount the pump to the front crossmember? Thats where mine is.
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 01-24-2004, 02:19 PM
Super Moderator
cstreit's Avatar
Tim,
Isn't it dangerous to have the pump exposed? I was thinking of mounting it somewhere that it (but more importantly the fuel lines) couldn't get hit with debris...
Chris no like fire.
Chris
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
Alcon Brake Kits
Old 01-25-2004, 01:59 PM
scca_ita's Avatar
Originally posted by cstreit
Tim,
Chris no like fire.
That what the steel cover is for that mounts to the cross member and rear supports. I am using a late style which is lighter and stronger.
Old 01-25-2004, 03:37 PM
what? me worry?
TimT's Avatar
Chris, your 930 has one of its two fuel pumps mounted on the front crossmember....
Porsche has mounted fuel pumps on the front crossmember for ages...
I cant get any pics for you as the permafrost has my car in itsd grips
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
BBS wheels
Fikse wheels
Redline motors oils
Swepco
Old 01-25-2004, 04:44 PM
Chris - Here is a link to a page on the Gunnar site and how the mounted twin fuel pumps near the tank. You can have one of these brackets fabricated for about 50.00 or if you want one I'll get the place that fabricated mine to do one for you. It's really simple. So you mount this bracket just to the right of the opening for the smugglers box close to the right side fender ( looking from the front of the car). I can send you a couple of pictures of how I did it. I also am running PMO webers so I use twin facet fuel pumps that are 4-5psi.
Old 01-25-2004, 05:15 PM
Super Moderator
cstreit's Avatar
Thanks guys.
I may just end up putting back underneath.. *sigh* Just wanting something more elegant.
daloff, I can't see the link. Pictures are good!
Chris
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
Alcon Brake Kits
Old 01-25-2004, 07:49 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
