Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche Autocross and Track Racing
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 3.40 average.
Super Moderator
cstreit's Avatar
Best affordable method for notching roll cage tubing?
Anyone have a preferred and preferably inexpensive method for cutting notches in roll cage tubing?
Chris
2001 GT3 Cup - "Pepin"
1996 993 RS Replica
2008 Yamaha R6
1971 Norton 750 Commando
Old 01-28-2004, 11:26 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
304065's Avatar
http://www.jointjigger.com/
These are used for experimental aircraft fabrication. Good stuff. Plus you could get into the cage business.
'66 911 #304065 Irischgruen
Ex-'88 Carrera (Sold 3/29/02)
Old 01-28-2004, 11:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Super Moderator
cstreit's Avatar
Ooof... Our ideas of affordable are different John.
Actually I saw a similar one at Harbor Freight... What kind of hole saw is recommended for mild steel?
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 01-28-2004, 11:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Super Moderator
cstreit's Avatar
Ah HAH!
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42324
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 01-28-2004, 12:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Grady Clay's Avatar
Try
http://www.eastwood.com/itemdy00.asp?T1=28040&I1.x=43&I1.y=67
for a Tubing Notcher @ $270. Looks to be the same?
You are also going to need a tubing bender.
Read the rules for your rollbar, particularly SCCA.
Good roll bars come from careful design, proper fabrication, and lots of trial fitting. Discard/recycle tubes that don't fit perfectly. TIG or MIG, you need to have a skilled chraftsman to do the welding. Even skilled fabricators end up with more scrap than in the roll bar itself.
What is your neck worth?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-28-2004, 12:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Super Moderator
cstreit's Avatar
Have the bender and MIG already... Fabrication will be based on proven designs. I had the main cage area done professionally, I'm just extending it out to the suspension points, so it's not as structurally critical.
Thanks for the info.
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 01-28-2004, 12:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
304065's Avatar
You're tellin' me. Here in New York there's a place that charges $20 for a martini! And the worst part is, everyone is fully clothed!
Old 01-28-2004, 02:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Super Moderator
cstreit's Avatar
That better be one BIG martini...
Will a standard bi-metal hole saw cut through the steel tubing, say 2"x0.095"acceptably? Or is there some sort of fine tooth bit that will work better?
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 01-28-2004, 04:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Originally posted by Grady Clay
Try
Facts of life:
  • Everything @ Eastwood can be found elsewhere at a fraction of the cost.
  • Harbor Freight is in the biz of making cheap copies of tools
That is all, you may now return to your normal lives (while I go get another beer...)
Old 01-28-2004, 06:36 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Super Moderator
cstreit's Avatar
Thom,
I agree, but there isn't enough to this thing, being is that it's just a jig and some bushings that justify the high cost...
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 01-28-2004, 06:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Never left, but not right
Zeke's Avatar
I tried the jig. Seems better suited for lighter, smaller tubing. I used a cut off saw to start the fish mouth and detailed it with a small angle grinder. I was working with .095 tubing. If for some reason you go with .125, I think you will find my method to be useful. And cheap.
Old 01-29-2004, 07:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Super Moderator
cstreit's Avatar
Milt,
How are you able to accurately lay out the curve with this method?
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 01-29-2004, 07:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Jeff Jagusch's Avatar
roll hoops
Hi Chris,
The guy that I've used builds VERY NICE all TIG welded cages. They do several a year as well as complete frames and other stuff and are all done per Milt's method.
I guess you just learn the trimming pattern as you get experience.
These guys will never weld a bar in place that has more than a .020" gap, and I've seen them work, and can say that they will spend more time than I have patients in trimming until it's perfect.
These guys are VERY talented!
I guess my point is that you don't need to buy anything special for what you are doing.
I would recomend a benchtop belt/ disc sander.
I'm sure even Harbor freight has one. It would help in the fine triming.
Good luck
Old 01-29-2004, 09:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
CRNT918's Avatar
Hey Chris,
Use Milwaukee hole saws!
Pete
PCA-Chicago Region-DE Tech Coordinator
1987 Cab-under construction
1986 911- Race/DE car-going up for sale
Old 02-01-2004, 07:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Super Moderator
cstreit's Avatar
Pete,
How long do these last though mild steel? I saw the bi-metal Milwaukee ones, but haven't found 'em big enough yet...
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 02-01-2004, 08:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
CRNT918's Avatar
I've used them over 4 inches in Diameter!
That's about 100mm.
Old 02-01-2004, 08:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Parrothead member
VINMAN's Avatar
I use a bi-metal hole saw, buy a good one. I cut it rough with the
hole saw then i fine tune the fit with a cut-off wheel or a die grinder.
Vinny
Red '86 944 '02 Dodge Ram, 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL
Old 02-02-2004, 05:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
what? me worry?
TimT's Avatar
The hole saws last a good long time if you use plenty of lube when you do the cutting. Ive built a cage or two, and use the harbor freight notcher, Its taken quite a bit of use and abuse and seems like new.
I was thinking of buying one of these and using it on my next project.
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 02-02-2004, 11:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Super Moderator
cstreit's Avatar
Is it 10x better since it's 10x the cost?
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 02-02-2004, 12:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
From the really old school...
Get some fairly thick paper. Wrap it tight around the tube and tape it. It should have just enough give to slide back and forth.
Hold one tube up against the other at the desired angle.
Slide and smash the paper into the mating end. It will crumple and form the general curve.
Trace with a dark pen. Grind and fit. repeat until the exact curve is reached.
With this method its hard to make your length to short. Notchers go TOO fast sometimes.
-Rich
Old 02-03-2004, 04:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
