People are just beginning to work on this. The basic issue is being able to extricate the driver with a minimum of motion/load to the spine, in order to avoid paralysis. James knows more about this than I do, but I understand the general protocol is to place a backboard between the driver and the seat back before the driver is moved. This is made more difficult by the presence of head surrounds. We have been told (emphasize secondhand info) that the HANS device can present a problem because, in order to remove it, the EMS crew needs to move the head forward, which they are loath to do. I'm not sure why the HANS could not be left in place, but maybe James has could chime in. See the underlined sentence in the fourth paragraph here: http://www.rsisafety.com/ |
So, When I was working EMS the goal was to get a backboard behind the patient while they were still in the car. This was done if the car was safe ie. no fires etc. Usually we had one person behind the victim to stabalize the neck until the board could be inserted. After that, it was pretty straightforward thought sometimes we would remove the roof if nessessary. One solution I have thought of is to remove the race car driver by taking out the seat with the driver in it. It's a great backboard if still intact and could make the whole operation much quicker and easier. As I said before, every situation is different and some procedures vary from state to state.
Cheers, James |
This is one of the most interesting threads on the subject I've read.
I too faced the same questions and concerns, and last winter, made my decision. I've raced with an H & N system for a year now, and I'll add my thoughts to the data set here, maybe it will help answer some questions. I read the papers and studied the test results, and it was obvious that the "Big Two" were HANS and Isaac. But, completely different methods to the same goal: hydraulic vs webbing. I boiled the decision into three areas: Protection, Ingress/egress, and Comfort. Protection . Really, it's a wash numbers-wise. But the Isaac looks to have significant advantages in off axis incidents due to its design. Of course, this is untested and just an off the cuff opinion. But the fact that the HANS is a strapped based system means future degredation of the straps, requiring replacement every two years, if you are to follow the recent standards. And most importantly, the HAS is dependant on prober adjustment, and the tighter the better, which affects...... Ingress/Egress: A tightly adjusted HANS is more effective than a loosely adjusted HANS. But also more restrictive. I was concerned about that, and felt the Isaac held an advantage here due to it's basic premise, which is that the shocks are loose until the velocity of an impact causes them to go stiff. (And that seems to me to be a nicer situation for my head as well. I know this isn't the perfect analogy, but the HANS reminded me of having my head attached to a rope. Not so nice when you get to the end of the slack.) But the major point is the ability of me, a 6'3", 200 pound guy, crawling through the window of an RX-7 upside down and on fire. I didn't like the look of the HANS. I imagined it would be too easy to get caught on something. (the same scenario caused me to put my net in with seatbelt buckles top AND bottom so that the net will always have a way to be released so that it falls DOWN, whether the car is right side up or not). I'm pretty good at not panicing when the s&!t hits the fan, and this summer I had a mild test, where I felt that there was a fire starting under the car and I wanted out, WITH the extinguisher, fast. I was on videotape, and was completely out in seconds, which included all the normal steps, plus switching the ignition off, popping the wheel, grabbing the fire bottle AND popping the pins on the helmet mounts. Finally, Comfort. I wish I could give back to back results here, but they are available to you from Isaac. They will provide both setups, I think, for you to decide. They have a rental program and they credit you the cost towards their system purchase. I will say that the Isaac is one of theose things that disappears in the heat of battle. It does make some racket in the pits, and if your car is quiet, it will be noticable. Also, backing up is now a mirrors only proposition. Which it has been for me anyway with the seat and the harness. So, the bottom line is that I like a number of items about the Isaac better. I feel that for a Formula car, the HANS is more the equal, but in a closed roof car, I wouldn't touch it. HANS haas been around longer, practically invented the category, but I haven't heard a rational arguement that has convinced me that they were, pardon the pun, head and shoulders above the rest. For me, the Isaac was a clear winner, and the company has performed as well as the item. Crash testing has been light, no aches to complain about. |
I dug up the article in Sports Car Magazine on Head and Neck Restraint systems. Look for it here:
http://www.logician.com/stuff/Headsup.pdf Sorry for the large 6MB size, but I scanned it in grey scale so that you could see the pictures of the various devices. You will probably need to download it to your hard drive first, as I've had very little luck opening large pdf files over the internet directly with Acrobat. While the article does not evaluate the various devices, it offers some comments strongly in favor of one device from Dr. John Melvin who has been involved in testing at Wayne State. Melvin says: "The only device we know of proven to protect at the highest crash levels we've been able to simulate is XXX. YYY came close, but..." I'll leave it to you to read the article for details. Another interesting point is some coments from Trevor Ashline, inventor of the Hutchens Device, that talks about the importance of tuning the whole system to work together. Unfortunately, it doesn't say how that might be done. I'm trying to get someone from HANS to respond to the issues raised about extrication procedures with HANS. I'm interested to hear what their response will be to some very good points raised here. -Juan |
Hey Juan,
Thanks much, I was looking for this article!!!! Later, Juan (also!) |
It's nice to see the article being written, but it underscores the need for the kind of third-party testing you talk about, Juan. I wish they had included more on what Melvin is basing his opinons on.
A lot of people have complained to the SCCA about that article. All we have is one person's opinion and no comparative data. |
I got a reply from Ken Adams of HANS to some questions that I culled from this thread. Here is my Email to Ken:
Here is Ken's reply: Quote:
http://www.logician.com/Stuff/ComparisonSheet06.doc And here is a PDF version: http://www.logician.com/Stuff/ComparisonSheet06.pdf If you have followup questions, I'll collect them and send them in a second Email. -Juan |
The documentation Ken Adams supplied draws on data from SAE paper #2002-01-3304, which is flawed--and Ken Adams knows it. So do Bob Hubbard and Jim Downing, who were sitting in the front row of the audience at the SAE conference when the paper's lead author, Dr. John W. Melvin, announced the errata. |
Gregg,
A few followup questions for you. 1) Can you tell us what was the verbal erratum that Dr. Melvin gave with the presentation of his paper. I would like to understand that fully when I look at the papers. 2) Adams writes about Isaac: "The thought of metal rods anywhere near your head or neck scares us, as we have seen a head and neck restraint with such a piece spear the helmet off of the crash test dummy on an impact rebound." I too had been concerned about the proximity of the Isaac rigid shock absorbers to the driver's head and neck. But I didn't know what to make of it. Can you tell us about the tradeoffs here? 3) When asked about the benefits of the Isaac shock absorbers compared to the HANS, Adams states: "There is enough compliance in the human body, as well as the shoulder harness to bring the head to stop gradually, every time. The tethers functioned well even in the 100G sled test (the most severe sled test ever performed with regard to Head and Neck Supports)" Do you agree? In what cases would the shock absorbers be required compared to the webbing? Also, at what G's will the shock absorbers begin to fail? Any other input with respect to HANS' Email would be useful too. I hope to send HANS a followup next week. Thanks! -Juan |
Juan, As I understand it, webbing is a static material, at least in the context of the Search and Rescue and climbing fields. I have wondered too how HANS is spec'ing this material and if indeed they are using a dynamic webbing to attach the helmet to the collar.
Cheers, James |
-Juan |
Juan, you are correct. In the context of webbing and rope, static means that the material is designed not to stretch( very bad for climbing ropes since the rope stops you suddenly). Dynamic means the material will stretch a given % over a specified distance.
Cheers, James |
James and Juan;
The webbing used in seatbelts is designed to stretch in an accident. This is why it is important to discard your seatbelts after an accident and get new ones. So I don't see anything unusual about the straps used in the HANS devices doing the same thing. |
What do the HANS folk think about the webbing degradation over time that has become a big concern for all the sanctioning bodies? (regarding harnesses)
Currently the SCCA, and others are on a two (three if purchased on the right date) year replacement plan. Also, what are their thoughts regarding the relatively poor performance in lateral situations, and the percentage of lateral incidents versus straight on? |
Actually, there is a very good thread by Vaughn Scott on Renlist that gives some really good info H&N restraint systems: http://forums.rennlist.com/rennforums/showthread.php?threadid=126126 Here is the text from the post (sorry for cross posting, but it seemed like the right thing to do in this case). Quote:
I noticed on TV that some of the Speedvision Challenge cars have interior nets. I think that's the way I will go for lateral restraint. -Juan |
I agree Juan...and the interior nets have the added benefit of easy removal, and to sme degree, visual transparency.
I like the cool seats (Momo, etc) with the extra section for head and shoulders lateral restraint, but from an ingress/egress point of view, I have worries that they would make a potentially small opening even smaller. On the downside, if the car is against a barrier or on its (left) side, the right side might be the only way out, and if the car is filled or filling with smoke/flames, an additional item to figure how to disconnect is an issue as well. But, we have to do a little "potential" analysis, and it's clear that its I would rather be conscious and at least able to attempt getting out after an incident, rather than injured and unable to fend for myself. |
Regarding the comments by Vaughn relative to the force reductions at different offsets, here is a chart showing the major players at a 30 degree offset. It would appear that right around here the Isaac and the HANS are roughly equal, with a slight edge going to Isaac.
I will point Vaughn to this thread. It would be nice to be able to plot all the devices on a matrix , and see which are better at what, but this is the closest I have found. I agree with Vaughn that a straight on impact just isn't that likely. In my crashing experiences, it has never happened. Even the one that LOOKED like it was going to be straight in was an offset when I finally hit.http://forums.pelicanparts.com/uploa...1081674537.gif |
Here are Vaughns thoughts on the HANS response. He requested I repost for him from his posing at: www.Improvedtouring.com in the general discussion area. To see the entire thread in it's context, go here: http://forum.improvedtouring.com/it/Forum10/HTML/001281.html
Jake, Thanks for posting that chart. I believe came from the Isaac site, yes? Here is the additional info given about the chart that really should be included with it:
One thing I don't like about the Isaac chart, and all the glossy charts from other manufacturers, is that they invariably portray their product as the best of all the alternatives. It is difficult to see through all the marketing spin what is really going on, and I'm always left to wonder why they didn't compare against products that I suspect might have performed better. I will note that the HANS data from SAE 2002-01-3304 quotes a figure of 195lbs in a 50G test. Presumably this is the data Isaac used to make its chart. So it doesn't make sense why the Isaac chart quotes a greater than 200lb figure with a lesser 45G load for HANS. Also the Isaac chart does not explain what the white areas in the bars mean. Probably there are variations in the tests that are not explained. For example, different seating positions surely affect the measurements. What are the charts comparing: F1 seating or production car seating? Or are they mixing test conditions? I am also guessing that maybe some products do better under different conditions, i.e. 45G vs 50G vs 70G. So probably the different manufacturers pick the conditions that portray their products in the best light -- you know kind of like the quotes in movie ads. For our purposes, we really need a comparison between the alternatives in our application -- production car seating. I would rather see that done by a third party that has no affiliation with the products being tested. -Juan |
| All times are GMT -8. The time now is 11:42 AM. |
