Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Super Moderator
cstreit's Avatar
This corner balance sound right?
Well interesting. I finally just set the corner balance independent of the ride height and came out with 23.5" rear, 24" front ride height. (+/- .25")
1388# cross weights each side.... Perfect.
Corner weights are
LF 560 RF 588
LR 800 RR 828
Scales are showing too much weight, but I calibrated them to me... Strange... My car ain't no 2700#!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-06-2004, 02:56 PM
Glenn from Denv's Avatar
I don't know why the scales would be wrong...your car is 2700lbs. One way to check is to drive over some truck scales (with or without your towing rig).
_______________
Glenn from Denver
94 964 3.8 RSR
Old 04-06-2004, 03:06 PM
Navin Johnson
TimT's Avatar
Its all those extra tubes you welded in Chris
'69 911 GT-5
'75 914 GT-3
and others
Old 04-06-2004, 03:24 PM
MMARSH's Avatar
Chris
Sounds like you put to many coats of paint of those purdy new fiberglass pieces.
Michael
Old 04-06-2004, 05:06 PM
Super Moderator
cstreit's Avatar
Glenn, Completely stripped racecar, fiberglass all the way around, and it weighed 2100# two years ago. Once again, ain't no way it's 2700#. Stupid bathroom scales.
Tim, I added 40# of roll cage and 30# of fiberglass, and took off 110# of steel.
Mike... sheesh, paint's too thin already!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 04-06-2004, 06:25 PM
PRO Motorsports
Tyson Schmidt's Avatar
Maybe your car is sneaking Oreo's in the night.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 04-06-2004, 06:36 PM
Have you kept your eye on your competition....
_______________
Glenn from Denver
94 964 3.8 RSR
Old 04-06-2004, 07:15 PM
Navin Johnson
TimT's Avatar
Could this be Chris playing cards?
He has a royal flush in his hand and he is only letting on a pair...
Poker face?
ok back to reality...Chris maybe part of the "hundred" digit on the LCD is effed up?
I dunno.... it appears you car should be light...
'69 911 GT-5
'75 914 GT-3
and others
Old 04-06-2004, 07:25 PM
Chuck Moreland's Avatar
I assume you are using the ruggles type scales? These use leverage to multiply the weight, by four. They also multiply the error, by four.
You calibrated them to yourself, at what 170 lbs? Cheap bathroom scales aren't that linear. Youd be better off calibrating using something that is very close in weight to the actual corners.
So given a combination of non-linear scales and 4x the error. I can see a 600 lb discrepency.
Chuck Moreland - elephantracing.com - vonnen.com
Old 04-06-2004, 08:08 PM
Somewhere in the Midwest
MotoSook's Avatar
psss! guys...don't say anything, but I added some lead in the cage tubing...mid season, I'll remove them and then we'll see him scoot heh hehhee
No really, it has to be the scales man! I'll stop in at the truck place on my way to work in the AM and ask if they will let us on the scale...yeah?
Old 04-06-2004, 08:09 PM
Super Moderator
cstreit's Avatar
LOL...
They have scales at the tracks, so I'll get the car on there to be sure.
I did find a few empty Guiness bottles in the garage that I can't explain... Perhaps Phoebe's been tipping on the sly...
I'm assuming that while the scales are clearly off a bit, that they are off consistently from one to the next. The total weight got higher as I honed in on the right balance. It read like 2100# this morning, by day's end the car had found 600 additional pounds!
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 04-06-2004, 08:45 PM
http://vintagebus.com/cgi-bin/balance.cgi?name=ctreit&car=&notes=&LF=560&RF=588&LR=800&RR=828
Old 04-07-2004, 08:47 AM
