Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
AddictionMS
Just wanted to follow up and see how things went with your locked diff project? What was the outcome and how do you like driving with a locked diff? Can oyu give me any feedback about a locked diff compared to a torque Biasing one.
Pros and Cons.
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 04-06-2004, 01:31 PM
addictionMS's Avatar
so some general impressions,
high speed corners are very similar, perhaps a bit more oversteer feeling if anything.
Slow speed corners there was more push.
biggest surprises came when driving through the pits, let go of the steering wheel for a second and the car straightens out in a quick snap, no more adjusting stuff with two hands unless in a straight line.
I loosened my rear bar (SRP) by two holes, and added 0.5 degrees more negative camber in the front and things started to feel better. I will need to give a more thorough review once I drive Thunderhill which I know much better (end of May)
The loosening of the rear sway bar made the fast sweepers less exciting, if you know what I mean, and the extra camber in the front got me the bite on the turn in on the slow corners needed.
I have no plans to switch my locked rear end out for a quaife or LSD at this point, I now have one of each sitting in my garage so I could.
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 04-06-2004, 02:11 PM
Thanks for the advice. I have both Torque Biasing and Locked. Wanted to know what you felt about the locked. I might sell mine but I think I might like it. Many old school racers seem to like the locked rear ends. Mine is Brand spanking new. Had it built and deilvered to the track due to a possible failure in my TB diff.
Mark Scott
Vintage 911 Racer
Old 04-06-2004, 02:32 PM
