Anyone using the HANS device part 2
OK, I'm starting a new thread, as the old one got really long. Here's a link to the old thread that has lots of good information in it:
http://forums.pelicanparts.com/porsche-autocross-track-racing/155276-anyone-using-hans-device.html Here is some new information to report: Has anyone else read the two SAE papers, 2002-01-3304 and 2002-01-3306, cited by Isaac as proof of the performance of their device? I have just finished reading them. Executive summary: a) the Isaac paper shows the device to be at a very early stage in its development, b) the data presented for Isaac is minimal, and not on par with the throughness of the data presented for HANS, Hutchins, and D-Cel, and c) the data presented for Isaac does not appear to support their marketing pitch. Here are links to the SAE page from which you can download copies of the reports yourself: http://www.sae.org/servlets/productDetail?PROD_TYP=PAPER&PROD_CD=2002-01-3304 http://www.sae.org/servlets/productDetail?PROD_TYP=PAPER&PROD_CD=2002-01-3306 The first paper (2002-01-3004) is by John Melvin, et al, and it presents 11 data sets, 3 for each of Hutchens, D-Cel, and HANS devices, and 2 for the baseline without any device. The report presents neck tension/compression and bending moment (both polarities) in two dimensions for each of the data sets, and also head excursion for a 30 degree angle 50G impact. The data sets include measurements for both new and used HANS and Hutchens devices. The HANS device that was tested was the 20RE model, the one that I have, and the one appropriate for production car seating. The figures reported in the paper for neck load are indeed exactly the numbers presented in the HANS glossy -- 5100, 868, 4000, 3971, for baseline, HANS, Hutchens, and D-Cel devices. As you might expect, there is a variation in the measurements, and these figures are averages of the three data sets for each case. I tried to correlate these numbers with the marketing data for Hutchins and D-Cel, but their marketing material doesn't actually quote any numbers -- only uncalibrated graphs of Hutchens against "other device". The second paper (2002-01-3306) is by Greg Baker, and it reports on the development of Isaac. It explains the theory behind Isaac, the results of three tests, and the refinement of the Isaac design after each of the first two tests. The first Isaac test measured a tensile neck load of +2500N/-3500N (compare to 868N for HANS). However, the mount on the helmet broke. The Isaac design was modified (read the paper for details), and a second test was run that generated neck load of +1400N/-2200N. Again the Isaac device broke. Again the design was refined, and the third test measured +1330N/-1250N, this time without mechanical failure. Unlike the Paper by Melvin, the Isaac paper does not report on the rearward neck shear force -Fx (whiplash?), the bending moments, or the head excursion. The Hutchins and D-Cel devices exhibit relatively high -Fx measurements around 2000N compared to HANS value of 237. The injury threshold for -Fx is 3100N, so this is an important measurement in addition to neck tension, Fz. It is notable that only one measurement was reported for Isaac in its final configuration, compared to the three data sets for each device that the Melvin report contained. I compared the numbers in the Isaac paper against their marketing material. The Isaac glossy chart shows a Neck load for their device of 200 lbs, or 890N. This is much lower than the 1330N value reported in the SAE paper. I am curious why there is a difference. As an engineer, I am concerned about the maturity of the Isaac, considering that the design and its parameters were just being developed circa 2002. The refinement done during testing included adjusting the damping factor in addition to fixing the strength of the components. Too high a damping factor, and your neck gets crushed instead of stretched. So what are the characteristics of the version of Isaac that is being sold to club racers? Are they the same as what was tested? What about the other test data: neck shear forces, bending moments, or head excursion? How does Isaac rate for these important measurements? I will be the first to say that I am not an expert on head and neck restraints. I have only been researching the subject for six months. Perhaps there are subtleties in the papers that are not evident to an engineer outside the field. If so, I hope that someone with greater knowledge will explain. Also, my report is not to say that Isaac may not be a good product on par with others, but only to say that the evidence cited for its performance is minimal, and further that it does not actually support the marketing pitch. If there is better evidence available, I would like to get about it. Finally, as an engineer, I am painfully aware of how the best designs in theory often fall short of their promise upon testing. So I value test results and, better yet, product maturity highly. If you have problems obtaining those SAE reports, PM me and I'll see what I can do to help. -Juan |
Juan,
Just a quick note to tell you I am a keen lurker on this thread and really value the effort and time you are putting in on this. I am learning a lot due to you efforts. thanks again Keep up the fight Jim |
Juan,
You once posted, “Engineers with partial knowledge scare me. I should know, I'm an engineer…” So far you have only partial knowledge. When I get a chance I will fill in some of the blanks on the original thread—I won’t post here. In the meantime, this is still correct: http://www.isaacdirect.com/html/chart. I’ll explain later. |
