930 calipers with bbs motorsport wheels
how thick of a spacer is needed when using 930 calipers with bbs motorsport wheels or will they clear the caliper fins clear without the spacers?
thanks |
Super Moderator
Depends on which wheel center. There are a huge variety of centers. Most should work without spacers though...
chris, i will probably be using the same bbs centers that were on your car in the photos you have posted.
They all look the same. They have a number stamped on them which identifies the amount of backspace or offset they have. Talk to someone who sells them and they should be able to help you out.
Super Moderator
Kev,
I run two different types of BBS's. THere's the 20 bolt modern style and the early "mesh style". THe modern style do come in different offsets though.. any ideas which offset you have?
Kevin,
IF you are discussing the real racing (20-bolt) magnesium centers), contact BBS directly at 770-967-9848. Jamie in the racing department is no longer there (we understand), but Bob Wilson should be able to help you. On the centers there should be a 4 digit code, and Bob will need that. Ed |
