Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
74goldtarga's Avatar
Dust shields
Do you guys leave the dust shields for your brakes on at the track? Do these perform some essential function that I haven't surmised? I would think that they interfere with brake cooling and should be removed. Any thoughts?
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 07-04-2007, 03:42 PM
Tom W's Avatar
Mine have been off for years. For a track only car, they serve no purpose.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 07-04-2007, 03:47 PM
Take them off, they reduce cooling.
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 07-04-2007, 04:34 PM
Do the Calipers and Rotors need to come off to remove the shields?
Old 07-04-2007, 05:22 PM
Yes, unless you are going to cut them off.
Old 07-04-2007, 06:28 PM
I still drive my car on the street, but not much, and not in rain - I'm assuming the recommendation is still to remove them.
Old 07-04-2007, 06:31 PM
Yes. They are actually stone guards as I understand it. Unless you plan to rally drive the car along gravel laden roads, you will be just fine w/o them. I would remove the hub to get them off properly, clean them up and put them away for possible future reinstall.
Tony G
2000 Boxster S
Old 07-05-2007, 05:50 AM
Chuck Moreland's Avatar
I believe their true purpose is heat shields. They help keep rotor heat out of the ball joint, tie rod, shock et al.
They probably also slow heat dissipation from the rotor somewhat.
So for a track car that is regularly inspected and service, it is beneficial to remove them. For a street car that you want to extend the life of the front suspension parts, leave them on.
Chuck Moreland - elephantracing.com - vonnen.com
Old 07-05-2007, 09:28 AM
ttweed's Avatar
It is not necessary to remove anything on the early cars to get the heat shields off. I have no experience with the later cars, but apparently, there is a possibility of bolts in the rear shield being put in "backwards", requiring caliper/rotor removal to get them out, as reported by Wil Ferch in this thread.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 07-05-2007, 10:10 AM
ttweed's Avatar
And required if you are installing a brake cooling kit, as the plenum and hose occupy the same space as the shields.
TT
Tom Tweed
R Gruppe #232
Old 07-05-2007, 10:16 AM
That is interesting Chuck, I hadn't thought about them shielding the suspension, but I think I'd rather have cool brakes. I will probably be going to a cooling kit at some point for the fronts.
Old 07-05-2007, 04:49 PM
