Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Plastic/lexan etc window question
hi guys
i'm re-classing my rally car for 2008 and will be able to run plastic/lexan windows. the front 1/4 windows, the rear screen and the rear side windows are sorted. however, i'm wondering how best to do the main door windows.
the two most common approaches seem to be a pull strap (similar to a 911R setup) or a fixed panel with a slidable opening.
please share what you have tried and found to work or not work etc.
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 11-28-2007, 03:25 PM
Ryan,
I have lexan side windows in 964 Cup car, they fit into stock location w/o any provison to raise or lower except by hand. Seems to work just fine. If you needed to raise or lower window much it would be a PITA.
Phil
Old 11-28-2007, 07:54 PM
hi phil,
what holds them in the up/down locations?
any chance you could post a pic or 2?
Cheers, Ryan
Old 11-28-2007, 09:18 PM
Super Moderator
cstreit's Avatar
I used a pull strap at the bottom with a snap for fixing it in the upright position. Not very convenient to get up and down but it did work and saved the weight of the window mechanism... I liked it better the the slide opening mainly because of egress. If you have to get out in a hurry, I imagine it's hard to get out of that sliding panel.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-28-2007, 09:31 PM
Ryan,
Just the friction of the plastic against the felt. Unfortunately car is 500 miles from me, if I get down for a visit I'll snap a pic of two for you.
Phil
Old 11-29-2007, 08:36 AM
Midwest R Gruppe
t6dpilot's Avatar
Ryan, I have the lexan pull up windows on my hotrod. I think they work great and add to the look of the interior - not that you are concerned about that. Mine is not a track car per se. I would recommend the pull strap lexan windows.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 11-29-2007, 10:22 AM
thanks phil
scott - can you post a pic of how the strap is attached and what it locks into?
Cheers, Ryan
Old 11-29-2007, 01:41 PM
73 911 3.2
Patrice911's Avatar
On my car I used a leather pull strap. At the bottom of the Lexan window I just drill a hole and bolt the strap to it. For the holder on the door I just used a bolt and machine the tread off the end and did kind of a ball at the end so that the strap doesn't pull away by itself. Using the remaining tread I just bolt it to the door and poke a hole in the door panel. You can see it a little in the picture below.
Patrice
1973 911 3.2 former track and AX car.
2016 VW GTI S PP
Old 11-30-2007, 06:22 AM
thanks patrice
Cheers, Ryan
Old 12-02-2007, 02:27 AM
Jeff Alton's Avatar
I have a complete set of Lexan here for my car (less the windshield). It will go in after the car comes back from paint.
Do you have a pic with the window up to see how much strap is inside the car??
Cheers
www.turn3autosport.com
Old 12-02-2007, 06:53 PM
73 911 3.2
Patrice911's Avatar
Cheers
Here the pics, I took them tonight. Different from the previous picture, the top of the door panel is now remove.
Patrice
2016 VW GTI S PP
Old 12-03-2007, 02:52 PM
Jeff Alton's Avatar
Thank you very much for the pics!
Cheers
Old 12-05-2007, 08:34 PM
