Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
abcdefghijklmnopqrstuvwxy
htron435's Avatar
Where to buy PFC 97's cheap?
Looking for a good source for PFC 97's. Thanks in advance.
Jay
2010 Spec Iron Mustang NASA GLD #113
(sold)1981 SC Coupe 3.6 (in '74 Carrera clothes)
(sold)1999 Spec Miata NASA GLD #113
jaynorthauto.com
Old 12-05-2007, 06:10 PM
Super Moderator
cstreit's Avatar
Jay,
I supply them to most of the GruppeB guys, 1-2 days shipping for you in OH. drop me a PM or e-mail if you want.
Chris
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-05-2007, 06:51 PM
Jeff Alton's Avatar
Chris, do you know if any of the compounds are available for the Brembo GTP's?
Ferrari F50 caliper and lotus twin turbo caliper...
Cheers
www.turn3autosport.com
Old 12-11-2007, 10:18 PM
jakermc's Avatar
Chris - are you able to special order 01 compound for 930 calipers, and if so, how much would these run? I am running 97 compound now but would like 01 in the rear to help improve brake bias.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 12-12-2007, 05:58 AM
Noel's Avatar
Chris,
There is a rumour going on at Rennlist that these pads have been discontinued. Any truth to that?
Noel
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 12-12-2007, 07:09 PM
Super Moderator
cstreit's Avatar
PF97's discontinued? I haven't heard that, but I'll definitely look into it. Left a message for my rep regarding possible discontinue of any of the old porsche plates.
I can get anything available from PFC, haven't done many special-order items but I can look into that, as I've been wanting to try 01's on my car to see if there was a difference. I should have something on that this afternoon as well.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-13-2007, 08:12 AM
Super Moderator
cstreit's Avatar
Jeff, I think those would be the 7780 plates and the 395 plates right?
Got 'em! Anyone else interested, please contact me offsite as I don't want to clutter up Waynes site with outside bidness....
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-13-2007, 08:27 AM
Noel's Avatar
OK, let us know Chris. It wouldn't surprise me if that was just a rumour. You know how the Rennlist Track forum is....
Old 12-13-2007, 10:48 AM
Jeff Alton's Avatar
Chris, what compound for a dual use car?
cheers
Old 12-13-2007, 11:35 AM
Super Moderator
cstreit's Avatar
Jeff,
There are two choices, each have their own compromises of course.
A number of the local guys here have been using the 97's on their dual-use cars. Obviously since these are a race pad there will be some downsides on the street. Some people have experienced squeeking (not all, no common denominator that I can see), and cold performance isn't as good as a full street pad.
They also make what they call a Z-rated pad for "Severe and high performance" duty. These will be better for the street without squeeking and better cold performance, but at the hottest track temps they will not last as long, more dust, more input required. These aren't available in as many of the exotic applications as the PF97's including the GTP calipers.
The 7780 for example is available in the 93, 97, 01, 03, and 05 compounds but not at all in the Z-rated. The 0345 is available in Carbon Metallic, Z-rated, and 97 compound.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-13-2007, 01:35 PM
Super Moderator
cstreit's Avatar
FYI there is no truth to the rumor that the 97 compound is being phased out for the Porsche pads. (My rep said he's been inundated with this question lately) This may have been started because there is probably a NEW compound coming out, but it is going to be different so the 97 will remain.
Still waiting on the PFC0345.01 avaialbility.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-13-2007, 03:20 PM
Jeff Alton's Avatar
I will check to see which sized pads I need, then pick a compound.....
Old 12-13-2007, 03:30 PM
Jeff Alton's Avatar
Chris, I believe they are 0595 rear and 7780 front. The Pagid #'s are 1408 rear and 1287 front...
Cheers
Old 12-13-2007, 09:03 PM
Super Moderator
cstreit's Avatar
Jeff,
Your option with PFC's is the 97 or 01 compound. The 97 would be suitable for dual use with the above caveats.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-13-2007, 10:00 PM
Jeff Alton's Avatar
Okay, I will contact you offline to continue the discussion, thanks for your help!
Cheers
Old 12-13-2007, 10:48 PM
