Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche Autocross and Track Racing
LinkBack Thread Tools Rating: Thread Rating: 14 votes, 3.86 average.
Porsche Crest Enclosed Race Trailer Flooring
Other than very expensive aluminum checker plate, what's out there for a durable, great looking floor for my enclosed race trailer????
When new, completely sealed the plywood floor per my tile dealer and installed a great looking black/white checkered tile floor. Within a year between the weather, oil drips and sticky tires the tiles started coming up.
Got tired of looking this mess, so this year I covered the floor with 1/4" exterior plywood and painted with exterior floor paint. Guess what, sticky tires now pulled up the paint and several areas of the plywood.
Would like ideas on what's out there???
Old 09-22-2008, 08:15 AM
Super Moderator
cstreit's Avatar
I've been thinking about truck-bed liner (liek RHino-liner) for our trailer floor. Seen a few trailers that used it, seemed to be golding up well.
Chris
2001 GT3 Cup - "Pepin"
1996 993 RS Replica
2008 Yamaha R6
1971 Norton 750 Commando
Old 09-22-2008, 08:31 AM
dweymer's Avatar
I just ordered a new trailer and am looking into the same issue. I was thinking about bed liner like Chris, or garage floor epoxy. I think I will try the garage floor epoxy first, it comes in a lot of different colors now.
D
Donnie
Currently Porsche-less.....
Old 09-22-2008, 10:00 AM
floor
Discussed the garage floor epoxy with several floor coaters (U Coat, Behr). Not recommended.
These coatings are for concrete only.
Trailer floors expand/contract where a concrete floor in a garage is fairly stable.
Old 09-22-2008, 10:28 AM
dweymer's Avatar
good point, so that's out.
Here is one bed liner available in colors
http://www.grizzlygrip.com/colors.asp
Donnie
Old 09-22-2008, 11:27 AM
coating
Not cheap.
At $88 to cover 24 square feet that equates to about $900 to cover my trailer floor.
Trailer & beaver tail is about 250 square feet
Old 09-22-2008, 12:03 PM
dweymer's Avatar
It says 50-55ft per gallon...
http://www.grizzlygrip.com/faq.asp
for my trailer it would be about 300ft. or 6 gallons for a rough $$ of 450. still not cheap. For cheap just buy linoleum flooring and glue it down.
D
Donnie
Old 09-22-2008, 12:54 PM
John Rogers's Avatar
In our toy hauler that doubles as a race car carrier I have strips of deck tread material where the wheels roll on and square that is large enough where each tire sits when strapped down. I aalso have a piece that is sized to fit under the engine and trans to catch drips. It has saved the tile floor that is in there, but I usually try to leave the car outside to let everything cool down when finished for the weekend but there have been times when I rushed it.
Old 09-22-2008, 02:05 PM
what? me worry?
TimT's Avatar
I have four pieces of diamond plate in my trailer located under each wheel. Figure out where the car usually sits in the trailer and get four pieces, two feet by four feet and screw down. Actually what I did was put down checkerboard tile, then screw down the diamond plate where needed
I've had this setup in my trailer for almost 10 years... no hot tires pulling up tiles etc
who are those guys? <<< ( Butch Cassidy and the Sundance Kid)
Rent a GT3RS from us!! Call or e-mail.
Transportation and Track support
Rudtners Racing
'69 911 GT-5
'75 914 GT-3
Authorised Haltech seller and installer
Authorised Unichip installer
BBS wheels
Fikse wheels
Redline motors oils
Swepco
1500 hp chassis dyno
Old 09-22-2008, 05:45 PM
dweymer's Avatar
http://www.kmtparts.com/catalog.asp?prodid=477952&showprevnext=1
Black and white one piece flooring, price is not too bad
Donnie
Old 09-23-2008, 06:20 AM
flooring
Called the source you provided-THANKS
Price is not bad and shipping to my zip code was $42.
Will be checking for a local CONGOLEUM dealer to see if they carry.
My problem now is how to deal with the painted floor. May need to rent a floor sander to remove.
Old 09-23-2008, 09:31 AM
dweymer's Avatar
If the paint is down secure it should be fine, if it is flaky anywhere you should sand that though.
Donnie
Old 09-23-2008, 10:45 AM
flooring
Talked with an installer.
The glue does not stick well to painted surface. Suggested sanding to remove as much paint as possible.
Old 09-24-2008, 05:52 AM
MBruns for President
JeremyD's Avatar
Greg Smith Equipment - look at their interlocking rubber tiles.
Old 09-24-2008, 10:13 AM
barney911rs's Avatar
Tiles or paint will be fine for most of the floor. Put down two lengths of diamond plate as runners for the tires to rest on. Mine has two runners or some sort of plastic or rubber (installed by PO) that have help up well. I make sure the car cools down some before putting it in the trailer. That will help as well.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 09-29-2008, 02:35 AM
