Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
ted ted is online now
likes to left foot brake.
ted's Avatar
hand grooved rain tires
Anyone have a pattern for grooving/sipeing some wider 710s?
I have the resources to do it just need a pattern.
They would be used on the street, 335 and 275 x 17 Kumho 710s.
Old 10-21-2008, 03:10 PM
ted's Avatar
patterns?
Old 10-21-2008, 07:09 PM
petevb's Avatar
Originally Posted by ted View Post
patterns?
Can't help with an actual pattern, but it would seem that's the easy part? What form are you looking for the pattern in- a 2d that you could print out?
These seem nicely done- wouldn't want to do some of those myself:
http://www.rogerkrausracing.com/RKR/groove.shtml
Old 10-21-2008, 09:24 PM
ted's Avatar
Thanks Pete, those are great photos of hand grooved R rated tires.
With a blue ball point pen I'd like to trace the pattern onto the tire.
Any opinions, would it be ok to to use the R6 intermediate photo as a guide?
Old 10-22-2008, 06:28 AM
petevb's Avatar
Looks good to me- that's the one I'd choose.
FYI, when I asked Kumho about this a while ago the responded with the following:
"Good day Sir,
In regards to the V-710 – the tire is molded at 4/32 on tread depth, we do not recommend you cut any grooves for you might cut into the belt package. Try a grooved tire the V700 as an alternative.
Another suggestion is to find a racetrack with a less moveable gravel scenario.
This is the only advise we can provide at this time.
Thank you for your support,"
This was a much less aggressive response than Hoosier, who basically said "don't even think about cutting our tire". I think both are in CYA mode, but I would worry about delamination if you cut too many or too deep groves. However if you use that inter as a guide, make sure the bottom of your groves are rounded, and watch the tires carefully when they are on I think it'll work. I'm interested- if you do it please post your experience.
Old 10-22-2008, 07:08 AM
ted's Avatar
Good stuff Pete, thank you.
The green 911 above did a couple hundred mile back road tour with grooved R6s.
Mine may see some light touring.
I suppose they would be worth a try if it rained during a TT.
Old 10-22-2008, 07:19 AM
73 911 3.2
Patrice911's Avatar
How about some Toyo RA1. That's what I'm using for wet track and the occasional street driving.
When they have too much wear for wet driving, I just finish them up on the dry and buy a new set for the wet/street.
Patrice
1973 911 3.2 former track and AX car.
2016 VW GTI S PP
Old 10-22-2008, 07:43 AM
ted's Avatar
Currently RA-1s on 18s are my street tire.
imho you have an excellent wet weather tire managment plan.
I have too much time so thinking of grooving a used 710.
Got an iron, gonna try it.
http://www.pegasusautoracing.com/productdetails.asp?RecID=1169
Old 10-22-2008, 08:07 AM
73 911 3.2
Patrice911's Avatar
Actually I got that one and it work pretty good. I used it on the RA1. The RA1 has different tread depth across the tire so I grooved the inside edge to full depth to improve water evacuation.
Patrice
2016 VW GTI S PP
Old 10-22-2008, 12:52 PM
Brandon Krause (Roger Krause Racing) told me that he does this often for high-end street cars (mostly Ferraris). You may want to call him and ask for some pointers.
Old 10-22-2008, 05:08 PM
