Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Schumi's Avatar
Emergency battery cutoff & alternator protection
I am wondering the correct way to wire in an emergency battery cutoff switch, or even multiple switches (One on dash, one on outside of car) in reference to switches with alternator protection. The car in question is a 944 series car. I have seen these E-switches with "alternator protection" circuits, which add an alternate set of contacts that disconnects the alternator from the circuit to avoid damage. My question is, is this actually needed? I swear I have seen cars with emergency switches with just the two posts wired to the battery circuit, nothing else. Are these alternator protection switches mainly meant for newer cars with mroe complex charging systems?
Any direction would be appreciated.
Also, anyone have pictures of where they have mounted their cutoff switches inside the car? I obviously would need to be able to reach it from my seat while strapped in, which limits it's location. I have seen cable actuated remote switches but have a distrust/dislike of them for some reason.
M
Old 11-18-2008, 07:08 PM
Schumi's Avatar
bump....?
M
Old 11-23-2008, 02:54 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I am by no means an expert on this. I can only tell you how not to do it, since we have not yet installed our replacement kill switch CORRECTLY
We decided to install a kill switch on our LeMons BMW and did exactly what you said- spliced it inline on the battery lead. It doesn't do what you need it to do. What you've accomplished by doing this is simply a way to quickly disconnect the battery but not kill the car. If the car is running and you turn off a switch wired this way? The car will keep running on alternator power!
You need to wire it into the alternator, ignition coil, or fuel pump to kill the car. And you don't want to use a two pole switch to wire both the battery and coil/pump/alt. through it because you'll have 12V constant wired to the coil/pump/alt and then be overriding the keyed ignition switch. That's why they make the 4+ pole switches.
And it's location is typically required by racing organization rules to be OUTSIDE the car in a prominent location with a lightning bolt decal to call it out, so TRACK SAFETY PERSONNEL can kill the power to your car following an accident. The goal here is not for it to necessarily be in a convenient location for the driver.
Kevin L
Present: '86 Carrera, 89 Corvette Z51 6spd
Past: '87 Carrera, 79 911 SC widebody racecar
Old 11-23-2008, 06:25 AM
Super Moderator
cstreit's Avatar
Two reasons not to use the basic 2-pole. As Kevin said, overrun from the alternator can keep the car and other electrical circuits running. The 6-pole (?) ones provide a large resistor to bleed off alternator generated power when shutting down. This not only shuts the car off but prevents damage to the alternator if the power has 'no place to go'.
Chris
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-23-2008, 08:32 AM
jerryw's Avatar
I put a write up on doing this at http://944spec.org/944SPEC/content/view/77/25/
You don't need the alt bleed off resistor if you are willing to risk a surge taking out your DME. Your choice. You do need to break the coil circuit (or similar) to kill the engine and electrics when the switch is activated
Jerry
Norcal 944Spec #552
Old 11-23-2008, 03:30 PM
I read Jerry's writeup quickly, but I think that is the same way I wired my switch. Worked flawlessly all season. Bought the wires/cables from Auto Zone, and the switch itself from Ogracing.com.
I made this diagram of the wiring, hope it helps!
-- Jim
1983 944
Old 12-03-2008, 07:05 PM
Schumi's Avatar
Yes! that is a big help. I'm all for getting this correct- I was in the paddock during a scare once when some spec racer ford that decided, for no reason whatsoever, to arc some wires and try to burn itself to the ground because of an electrical fire. The car did not have a properly wired cutoff switch and the only way to cutoff the battery was to take part of the bodywork off and pull the connector from the battery. Everyone jumped in and got it off in time but it could have been worse if someone hadn't noticed the smoke.
M
Old 12-04-2008, 12:16 AM
Mahler9th's Avatar
Porsche alternators typically don't require the resistor, but it cannot hurt. I have seen many race cars in our area use two pole switches, I opted for a six pole. One key thing is to triple check all of your crimps and your routing (to ensure there can be no chaffing of insulation on hot wires).
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 12-04-2008, 10:27 AM
jerryw's Avatar
Yup -- that's how I did it.
If I can grab that diagram I'll add it to the write up if you don't mind.
Jerry
Norcal 944Spec #552
Old 12-04-2008, 12:52 PM
I don't mind at all.
-- Jim
1983 944
Old 12-04-2008, 07:03 PM
jerryw's Avatar
Great -- thanks
Jerry
Norcal 944Spec #552
Old 12-04-2008, 07:40 PM
aftermath's Avatar
where on earth is best to mount a cut off switch, my rules say on the cowl, there is no cowl on the 944, the fender doesnt seem like a good place
theamsoilguy@hotmail.com
Old 05-21-2009, 12:13 PM
On the 944, we have made a bracket to mount it adjacent to the battery, as low as possible below the hood line. then we attach a pull cable that is long enough to be exposed on the base of the windshield.
Remember to use proper insulation on all connectors so you don't start a new welding project!
1970 914-6 street"evil cockaroach"
1970 911 Spyder
1970 911S Conda
Old 05-21-2009, 01:08 PM
Super Moderator
cstreit's Avatar
Dave's spot on. You can go down to your local auto-parts store and buy a "manual choke" cable to use as a pull from a remote location. I had my switch on the outside with a cable that also leads inside in case I need to pull it while belted in.
Chris
1999 Spec Miata
1996 993 RS Replica
2010 Harley 48
2013 Honda 250 CRF
Alcon Brake Kits
Old 05-22-2009, 07:19 AM
Just put in a kill switch on my 911. Porsche makes a 6 pole that was installed in the 964 Cup Cars... about $90.00. My shop wired it so it kills the DME relay and the fuel pump, along with disconnecting the battery.
1986 911 Carrera POC JI/R7
1989 928 S4
Old 05-22-2009, 07:40 AM
Wer bremst verliert
JohnJL's Avatar
Is it necessary to wire in the coil to the cutoff switch? Is it acceptable to leave the two terminals for the coil in the diagram below blank? It seems to me the cutoff would still function properly as the main power supply would be cut AND the resistor would bleed off the spike?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 09-23-2009, 04:53 PM
Wer bremst verliert
JohnJL's Avatar
Like this?
Old 09-23-2009, 05:34 PM
The coil part of that circuit doesn't have to be used on the coil. In fact it is usually used on the ignition box (switched lead of the MSD or other CD box). It can also be used on the fuel pump relay or DME relay. It can be connected to anything that will make the motor stop running. Without it the engine will keep running. In the example you show the engine will keep running using the alternator power to run the fuel and ignition systems. The resistor to ground will just get hot since the alternator will be powering it as well. I suppose if you made the resistor such a low resistance that it was a short to ground the alternator wouldn't be able to maintain enough voltage to keep the engine running but the resistor would sure get hot while the engine was spinning down and I would think the overload on the wires and alternator would be harmful.
-Andy
Old 09-23-2009, 06:56 PM
Wer bremst verliert
JohnJL's Avatar
Thanks Andy. It would be more convenient physically to cutoff the fuel pump but I dont think that would work well...this car has Webers and it would seem to me the car would continue to run for at least a few seconds off the fuel left in the bowls?
Instead of the coil wire, which I would think would be particularly sensitive to any voltage drop experienced across a 15 foot run of cable from the engine to the front and back again, I'm thinking maybe of running the MSD "on" wire through the kill switch. I run a JBRacing twin-plug dizzy with two MSD boxes. The MSD 6A boxes have a "light" red wire that gets switched power and a "heavy" red wire for its mains power. In this case maybe I'll use the kill switch to interrupt the MSD light red wire?
Old 09-23-2009, 08:27 PM
Does anyone have a REALLLY good write up for this? One that the home mechanic can follow?
Old 09-25-2009, 12:08 PM
