Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
jmz jmz is offline
jmz's Avatar
what are you guys that race vintage using for tires?
I'm curious what tires those of you that run 15x8 or 15x9 wheels are using for tires and what you might use next year in SVRA with the new rules coming into effect.
SVRA RULES:
Group 8 - Molded Treaded Tires
Minimum aspect ratio of 45, except
certain car Make and Models, which
have specific tire requirements listed
in their Supplemental Regulations,
tread depth—no less than 2/32”
remaining, at all times, over 75% of
the tire.
Wheels may be of an alternate
material but must be of period
design. They must be the correct
diameter and width as specified
within the Supplemental Regulations
of the Make and Model.
Tires may not extend beyond the
fender opening at the highest point
of the tire.
Approved tires:
There are no specific sizes listed because of the large diversity of Group 8 cars.
All Group 8 cars must use similar sized tires to what was used in the day, which is pre 1973.
Using oversized tires is unacceptable and when in question, SVRA’s determination shall be
the final word.
Avon: ACB9, ACB10, CR6Z
Goodyear Eagle: 5.50/15 G12 or G12A
Hoosier: Street TD & Speedster
Any Treaded, DOT approved Tires with a UTQG of 100 or greater with appropriate
Speed Rating and a minimum Aspect Ratio of 45
Note: Group 8 must use approved full molded treaded tires, regardless of what
specification tires a car may have competed with in a prior race series.
For Toyo RA1’s and Nitto NT01’s, please see page 6 of this documen
Thanks in advance.
Jay
'74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'80 911SC Weissach 3.2 Short Stroke Hot Rod
'68 SWB 911T build in progress -The Rat
Old 09-07-2017, 02:26 PM
jmz jmz is offline
jmz's Avatar
circling back on my own post. It sounds like Hoosier TDs will be the tire of choice for SVRA. If anyone else has any other thoughts please share.
Jay
Old 09-08-2017, 06:56 AM
phigreg's Avatar
Vintage tires
You will need to look at page 6 to see the reference, but I would look seriously at the NT01 or RA1 in the 225/45/15 size or 225/50/15.
Not sure of the grip of Hoosier TD but the RA1 and Nitto have very good grip and last well and likely cheaper than the Hoosiers
Greg
Greg Phillips
1986 928S & 1989 928S4
1982 911SC track car
1986 911 Cabriolet
1991 968 M030
Old 09-10-2017, 06:49 PM
jmz jmz is offline
jmz's Avatar
Greg
I read over page 6 and RA-1 and the Nittos are not going to be allowed at all in 2018 which is causing my problems. I think Hoosier TD and Michelin TB series are possible options (The TB are like $400.00/ tire) but require a retune of my suspension. Looking for a radial that would work.
Jay
Old 09-11-2017, 07:54 AM
jmz jmz is offline
jmz's Avatar
I had some correspondance with Rick at SVRA and so far the R888R is not on the endangered list so I think I'll try them for the end of the year and next Spring.
Jay
Old 09-11-2017, 05:58 PM
Super Moderator
cstreit's Avatar
I used the TD's back in my vintage days in a 70 ST replica. They required fairly soft spring rates because of the amount of sidewall flex. That said - the slip angles they can run at were fun.
They were a competitive tire so long as everyone was on vintage specs.
No idea if they are faster/slower than the RA1s though... As a bias ply its a very different world.
Chris
2001 GT3 Cup - "Pepin"
1996 993 RS Replica
2008 Yamaha R6
1971 Norton 750 Commando
Old 09-12-2017, 08:29 PM
following this thread, I've been debating the same dilemma for months now
I'm thinking about buying a set of TD tires over the winter
I hate to make that jump, because of the completely different set up required
I don't want to switch set ups depending on which group I am running with
so considered going both feet in with a bias ply at my home race organization too.
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 09-22-2017, 07:27 AM
What do you recommend for tire pressures for the Hoosier TD's ?
Old 10-27-2017, 06:36 PM
Super Moderator
cstreit's Avatar
http://www.bobwoodmantires.com/wp-content/uploads/2014/10/Hoosier-pressures.pdf
Chris
1996 993 RS Replica
2008 Yamaha R6
Old 10-29-2017, 06:24 AM
Plavan's Avatar
RA1's were the goto when at COTA with SVRA a few years ago. Not sure if they nixed them. I could not run them on my car becasue they were not wide enough.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 11-04-2017, 07:42 AM
