Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche Autocross and Track Racing
Olsen911's Avatar
Porsche 911 trail arms.
Gents.
My Good Porsche Shop alignment guy says that my trailing arm is bent,
Porsche 911 2.3 ST 1971 all racecar.
There is a tool P295B:
I donīt have this tool.
Is there any measure that can apply to check rear trailing arm for straightness.?
Thanks - Cheers - Olsen911 - Tommy Olsen
"If everything seems under control, you're just not going fast enough" Mario Andretti
Old 10-04-2017, 12:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
It's a 914 ...
stownsen914's Avatar
How did the shop determine that the trailing arm is bent? Is the car not aligning as expected?
If your trailing arms are original, they should be the early LWB steel ones. I *think* the aluminum ones off a 74-89 911 should fit, in case it comes to replacing them. The aluminum ones are supposed to be stiffer and may be a good upgrade.
Scott
Old 10-04-2017, 10:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Olsen911's Avatar
Porsche 911
Thanks Scott.
My rear end is loose and the alignment guy has read the tires and says that i need more negative camber.
But he canīt give me more without jumping out of specs. so he told that one of the trail arms is bent.
I would like to confirm this, somehow.
My trailing arms are the original early LWB steel ones and upgrade to alu. is not legal, class rules.
Scott - please share your specs.?
Thanks - Cheers - Olsen911 - Tommy Olsen.
Old 10-05-2017, 01:42 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
It's a 914 ...
My 911 has 930 trailing arms and the chassis has modified pickup points, so I'm not sure this will be a good comparison, but I get 2 degrees negative camber easily, and more is available.
What camber setting are you getting with your current setup? What exactly is causing him to conclude that the arms are bent?
Old 10-05-2017, 04:20 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Super Moderator
cstreit's Avatar
Just because he can't get all the camber you want doesn't mean they are bent....
Some cars simply can't get more than 2-2.5 degrees. Where is it set?
Chris
2001 GT3 Cup - "Pepin"
1996 993 RS Replica
2008 Yamaha R6
1971 Norton 750 Commando
Old 10-07-2017, 04:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Olsen911's Avatar
Here is my specs.
It’s in Danish - Sorry.
Let my know if i should translate.?
Old 10-08-2017, 11:18 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
It's a 914 ...
Nothing there seems obviously wrong. Did he indicate what makes him say the trailing arm is bent?
Scott
Old 10-08-2017, 08:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Olsen911's Avatar
Thanks Scott.
Would like to have 2 - 2.5 degrees camber on the rears, but itīs toe out when trying to adjust.
That was leading us to think that the Trail arm is bent.
Let me know what you guys think.?
Old 10-09-2017, 11:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
kent olsen's Avatar
Tommy caught me by surprise as your address "olsen911" is one of the addresses I use on some of my car forums, not this one.
Kent Olsen, family originally from Denmark. I believe name started out Olesen but Grandpa keep loosing mail to the other Olesen in town so he dropped the first "e".
Anyway my 72 had the original trailing arms and there was a little evidence it had been hit in the left. No tire wear or visible problems but something was wrong as I keep wearing out the left wheel bearing. Finally replaced trailing arms with aluminum, which also have larger bearing and never had a problem after that. Now 240,000 miles.
Kent
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
RGRUPPE #104
Old 10-10-2017, 10:02 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Plavan's Avatar
Use Aluminum arms for the win.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 10-16-2017, 07:35 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Fubawu's Avatar
Chad
He says that it's not legal for his class? I have to say that is very picky for vintage racing , all classes here allow this upgrade.
I mean you could always swap out with another steel arm and see how it specs out?
1971 911T 3.2 1971 911S 3.2
1972 911S 2.8 1972 911T 2.7
1965 911 300760 1976 911S IROC
Old 10-16-2017, 09:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
PRO Motorsports
Tyson Schmidt's Avatar
Just an FYI. I've seen some mechanics claim the arm is bent because one side can get more camber than the other. And then it turns out that the toe eccentric was fowling the adjustment on one side.
To avoid this mistake, i always tell people to remove the toe eccentric when adjusting camber, then reinstall it to adjust toe once camber is achieved.
R-Gruppe member #382
'69 911E coupe' 3.2 (retired 911-Spec racer)
'72 911T Targa
2004 GT3
Old 10-17-2017, 09:14 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
safe's Avatar
You can install the toe adjuster two ways, one won't give you full camber.
Magnus
911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI
Old 10-18-2017, 07:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
WideRide 86's Avatar
^^This
Sometimes a little filing of the adjuster slot is needed (or can be helpful).
I had one shop early on tell me they couldn't get more the 2deg with both sides matched. I now have just shy of 3deg on both sides. Some shops know the tricks to get the camber. Good luck.
Old 10-19-2017, 03:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Olsen911's Avatar
Thanks Guys.
I will check if the toe adjuster is the wrong way around.
Old 10-24-2017, 05:06 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
