Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
jmz jmz is offline
jmz's Avatar
Any thoughts on tire pressure for Hoosier R7?
I cannot run anywhere near the recommended pressures from Hoosier without the car feeling like it is on ice. First time out I started at 22 with a target of 27. This past weekend I backed it down to a hot target of 25 and it seemed like they held up better during the 20 and 25 minute session but I'm still not sure I have it right.
Any thoughts? Car is a 914/6 GT at about 2100lbs without driver.
Jay
'74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'80 911SC Weissach 3.2 Short Stroke Hot Rod
'68 SWB 911T build in progress -The Rat
Old 12-12-2017, 05:38 AM
jmz jmz is offline
jmz's Avatar
Am I the only one running these?
Jay
Old 12-13-2017, 04:27 AM
jmz jmz is offline
jmz's Avatar
...Jeff at Hoosier is very helpful. I called and got some guidance but I'd still like to hear from anyone with experience here.
Cheers,
Jay
Old 12-13-2017, 06:45 AM
Pete R's Avatar
I use them. I have a 3000lb fwd car. I have had good luck running the recommended hot pressure about 39-40. I think they are actually better at the higher pressure. I used to run them a bit lower (-5lbs) but I ended up at Watkins Glenn this year. I was worried about an under inflated tire through the esses at 100+ MPH so I pumped them a bit more. The car felt better to me and the wear is even so I'm going to stay there.
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 12-13-2017, 10:05 AM
HarryD's Avatar
Jay, I do not know the answer but a tire pyrometer will help you get to the correct place. You want the tires to be at the recommended temperature and even across the tread.
I have this one: https://www.amazon.com/Joes-Racing-54005-Pyrometer-Adjustable/dp/B005JVFTTM
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 12-13-2017, 09:12 PM
Racer
winders's Avatar
Only if you can measure the temps in real time......you can't with a pyrometer. If you measure and the temps are the same across the tire the inside part is not hot enough.
Scott Winders
PRC GTL #3
Old 12-14-2017, 11:12 AM
HarryD's Avatar
Winders. Really? If you use a proper pyrometer like the one I posted, you do get the proper readings since it pushes a probe into to rubber at each point.
If you use one of the IR types then you are correct as they only measure surface temperature and you are never sure exactly which part you are measuring.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 12-14-2017, 11:23 AM
we run around 34 on our 87 911.
These tires are designed to run at higher pressures.
Old 12-16-2017, 03:40 PM
Racer
winders's Avatar
Really!!
Think about it. With the camber we run these days with radial tires only the inside third of the tire is on the ground unless we are cornering. As soon you stop corning the outside 2/3rds of the tire is starting to cool...even the tread below the surface.
Scott Winders
PRC GTL #3
Old 12-16-2017, 04:50 PM
HarryD's Avatar
Really!!
Funny, I see them used in all sorts of tracks.
I know these guys may know a thing or two about about such things:
https://www.elephantracing.com/tech-topics/reading-tire-temperature/
Or perhaps these fellows:
http://www.hoosiertire.com/images/content/files/TCTR7_A7.pdf
But believe what you wish. OK by me.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 12-16-2017, 06:21 PM
Ditto what Winders said. Infrared or a direct probe, doesn't change the fact that going in a straight line a cambered tire's inner shoulder stays hot from the uneven load/flex, while the outside cools. You want linear temps not even. And don't trust everything you read on fancy websites, talk to the actual people that actually race ;-)
Spec 911 just started running the R7, 2350 lbs with driver and everyone seems to like around 33-35psi.
Old 12-18-2017, 09:36 PM
jmz jmz is offline
jmz's Avatar
Interesting that the 914 driver feedback I've received considerably lower than what is being reported here which is inline with what I was feeling. ...24-27 hot seems to be the consensus that I received on the 914world forum.
Jay
Old 12-19-2017, 05:56 AM
Cory M's Avatar
We run them near the Hoosier recommended range on our 2450 pound 911, 33-37 pounds depending on conditions and age of the tires, usually around 2 pounds more in the rear.
Old 12-19-2017, 08:06 AM
HarryD's Avatar
Agreed that interpreting the results is the big deal.
For I, who Autocrosses, I find that trying to get a flat temperature profile works best.
Harry
2003 BMW Z4 3.0i
2009 MB C300
Old 12-19-2017, 12:49 PM
Administrator
Jack Olsen's Avatar
Right. There's nothing wrong with using a probe-type pyrometer, but (as Winders points out), as soon as you head into the pits, your outside half is going to be cooling down faster than the inside half. Especially if you're checking your own temps, you have to adjust your results for the change -- you won't want to see the same temps outside/middle/inside anymore, but something that reflects having been in the neighborhood a short time ago.
Old 12-20-2017, 10:28 AM
