Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Racer
winders's Avatar
Originally Posted by safe View Post
This is a coil over car, so the loads isn't that great.
I would not mess with this and instead would get ERP 935 A-arms.
Scott Winders
PRC GTL #3
Old 04-18-2018, 12:46 PM
safe's Avatar
Too expensive and won't fit under my 15s, if I've gotten the dimensions right...
I've shaven down the big ball joint castle nut, removed the cotter safety pin, all to get a few mm of clearance. Tightened the nut down with a chisel and sledge hammer.
Otherwise the adjustability would have been just super.
Magnus
911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. Just works!
911T Coupe -69, 3.6, G50, "RSR", track day. Sorting out issues...
924 -79 rat roddy...
931 -79 under total restoration...
Old 04-18-2018, 01:10 PM
safe's Avatar
Originally Posted by Manda Racing View Post
How do you align the steering wheel up after having all part?
Not sure what you mean? Just a normal alignment?
Magnus
Old 04-18-2018, 01:12 PM
Manda Racing's Avatar
Just getting top dead center of steering wheel to match up with shackle on steering .
I assume done underneath. I hooked mine up and didn’t check to see if rack was in the straight position.
Old 04-18-2018, 01:36 PM
It's a 914 ...
stownsen914's Avatar
Yeah, on the last set of a-arms I cut them further in.
Not questioning your fabrication skills, but don't under-estimate the loads that the A arm will see. The rotational load will be less since you've got coilovers as you've noted, but the lateral loads will still be there on the A arms when cornering, and also the longitudinal loads when braking.
Old 04-19-2018, 10:32 AM
Racer
winders's Avatar
You can get ERP with heim joints instead of ball joints....and the spindle height can always be adjusted to make room....
Scott Winders
PRC GTL #3
Old 04-19-2018, 04:47 PM
safe's Avatar
I have just gotten an alignment and done my first Auto-x:ish (very fast slalom course).
Settled for 3 degrees of camber, 7+ degrees of caster and a slight toe in.
Front end feels very nice. Could have gotten more camber and more caster if I wanted.
The rear however is somewhat "lively" and very demanding on the road....
I have about 3.5 degrees of camber in the rear with some toe in.
I think it would be better with only 2 degrees of camber in the rear.
I have ~285s on 11" rims, relatively light car (2400lbs total, 1500lbs rear, including driver) with 400/600lbs springs?
Is my thinking correct that less camber would/could be better when you are stiffly sprung and have wide wheels?
Magnus
Old 06-18-2018, 07:27 AM
7+ plus the add camber curve sounds great!
extra grip in front is probably the reason the rear feels lively.... perhaps keep the rear camber at 3 soften the rear springs and or get smaller front tires?
Old 06-18-2018, 09:57 AM
safe's Avatar
...or get wider rear tires , I got room for more rubber there.
But I just feel that I don't get the full potential out of the rear and its very darty.
Magnus
Old 06-18-2018, 10:34 AM
9 and 285 11s seems so right for these NA cars. what are u running up front? you have ruin the balance with your grippy improved front end now ? :-)
Old 06-19-2018, 06:48 AM
safe's Avatar
Michelin TB5.
The size is declared 23/60 (270) in the front and 26/62 (285) in the rear.
There is a rear 29/xx (305) availible.
Old 06-19-2018, 07:11 AM
rkeele's Avatar
285 on 11's is to small try 305 or 315 in rear
Old 07-22-2018, 08:50 AM
any pics with your new wide track front end?
Old 07-23-2018, 02:04 AM
safe's Avatar
The 26/61 is recomended between 9.5" to 11" rims and the next size 29/61 (335) from 11"-13". So next set might be 29/61.
Magnus
Old 07-23-2018, 02:22 AM
safe's Avatar
Haven't taken any pictures, that I can find. Doesn't look much different because the aren't much wider than what was on it, but the increased caster has nearly eliminated the tire scrubbing against the wheel well, its just touches when I turn full left.
Got some other issues with this car, this is one...
Magnus
Old 07-23-2018, 02:37 AM
