Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
987.1 scca stu
Is anyone running in SCCAs STU class and PCA Production autoX class?
If so what legal modifications for the classes are you running that make the most difference?
Can one be competive across both organizations with the same 987.1?
Old 05-28-2018, 06:35 PM
I only know about STU, I could share what I would do for my build and you could compare it to PCA rules.
First, wheels and tires:
For STU MR cars you get a 255 tire max, 11" wide wheel max. I'd shoot for the 255/35-18 RE71, as it's short at 25" which helps the abysmal Porsche gearing. That tire is rated for a 8.5"-10" wheel, so a 10" rear for sure. Not positive on what fits up front or if you can get that tire all the way around, but I'd try.
Next, suspension:
Camber! A decent set of coilovers that raise the ride rates to 1,8-2.0 Hz would be a guess start, but the car needs camber, especially up front. You can do camber plates or gt3 LCAs but not both. I've heard that camber plates are the better choice because they let you pull the top of the tire in, making more room in the wells for tire.
Honestly, I think that would get you about 90-95% of the way there. I've read there is not a lot of power on the table with headers / tune, so cost/benefit would not be so great on that. Dropping some weight with exhaust / battery is always good. And, depending on setup / swaybar choices, there's a possibility an LSD would be a real good idea. But since that's a little more invasive and not as easily reversible I'd put it off until year 2 or 3 of development.
I'm a proponent of doing a "lite" build first to see how things go. A couple of fairly quick bolt ons and you can get a good idea of how the car would be in full bore STU trim. If the car drives well, is fun, and is competitive enough, that's motivation enough to further the build. If things are immediately pear shaped, it's a quick and easy return to stock with minor financial (and mental) consequences.
Matt - 84 Carrera
Old 05-29-2018, 03:00 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Which PCA rules are you talking about? Different parts of PCA follow different rule sets, sometimes even on a Region-by-Region basis! And then there are the Parade Competition Rules (PCRs)...
--DD
Old 05-29-2018, 08:22 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
^^^ +1. Here is a link to what Zone 7 is using.
http://zone7.pca.org/wp-content/uploads/2018-Zone-7-Autocross-rules-final.pdf
If you list your location, you may get more help.
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-29-2018, 02:29 PM
Zone 1 PCA
Has anyone here set up a 987 STU SCCA vehicle? If so what parts do you feel are the best for the price?
Old 06-05-2018, 05:26 PM
