Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
P0017 Exhaust camshaft position with respect to crankshaft timing
Hi Guys,
I have the P0017 faulty code and I am trying to replace the camshaft position sensor. But I do not
know the location of this sensor ? Could someone help ?
Thanks,
BT
Old 01-13-2019, 03:26 PM
Administrator
Dmitry at Pelican Parts's Avatar
What year/model is this in reference to?
Old 01-14-2019, 04:11 PM
Hi Dmitry,
Porsche cayenne 2004 non turbo. Also, do you know if this is a DOHC or SOHC ? It looks like it is a VR6 engine but I am not sure.
Thanks,
BT
Old 01-15-2019, 03:16 PM
Hi Dmitry,
Sorry I forgot. It is 3.2L V6. Also, do you know if this has a single cam shaft for intake on one side and single
cam shaft exhaust for the other side ? Not dual cam shaft for each side ?
Thanks,
BT
Old 01-15-2019, 03:29 PM
On my 06 Cayenne S there located at the rear top of the engine, one on each side. Need to remove my air pumps and engine sheet metal to see them.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 01-16-2019, 12:56 PM
Hi Determined,
Thanks. I will try to look at that location. So, did you also get code P0017 ? And replacing it, worked for you ?
Regards,
BT
Old 01-16-2019, 02:16 PM
No, but I had once a crankshaft sensor error, turns out it was due to oil additive I put in. Once the engine warmed up and mixture was done it was fine. I also add restore every 2nd oil change, engine runs strong even after 130,000 miles on it.
Old 01-18-2019, 10:57 AM
