Air Conditioning
2006 Cayenne Turbo
Right side(passengers side) AC doesn’t get cold. Driver side is ok. Last edited by N1bl@aol.com; 08-14-2019 at 08:28 AM.. Reason: Spelling |
Administrator
Hello and welcome to the forum! It could be a defective 'blend door' motor or actuator. Other members will likely chime in as well.
My other ride is a C-130J
Dmitry is probably right, but to be sure you should pull the codes.
I’m having a problem with my A/C blower so I put my Durametric scanner on the car and got 3 related codes. I’m going to pick up a relay from our host then replace the front blower relay, clear the codes and see if that fixes the problem. After a while I’ll check the codes again to see if the other 2 come back. I’ll try and upload a photo of my Durametric scan
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
