-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/)
-   -   2008 Cayenne - radio issues (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/1049165-2008-cayenne-radio-issues.html)
Raulg 01-05-2020 09:34 PM
The radio/cd player in my Cayenne, started to dim recently. At times it takes longer to turn on compared to when new.
Would anyone know what causes this condition?
If the radio head unit is going bad, is there an aftermarket replacement?
Thank you
RG
RNajarian 01-06-2020 03:54 AM
When my 2005 began experiencing electrical gremlins it turned out to be an old battery
http://forums.pelicanparts.com/porsche-cayenne-macan-forum/782733-haunted-cayenne-crazy-electrical-malfunctions.html
Hope it is as simple as this
Raulg 01-07-2020 08:48 PM
RNajarian,
Thank you for sharing your experience.
I will have the battery checked this weekend.
I have had this Cayenne for 2 years now. I don't know how old the current battery may be.
I appreciate your help.
Thank you
RG
RNajarian 01-07-2020 09:36 PM
My pleasure. Hopefully it is the battery. If a battery lasts 5-6 years then likely your car is in its second battery. . . . Which means it is 5-6 years old.
Fingers Crossed
island911 01-11-2020 10:55 PM
there is an ambient light sensor to the upper right of the screen. If that is covered (made dark) the screen will dim.
Raulg 01-28-2020 04:56 PM
Update; I was able to take the battery out and have it checked at the auto parts store.
According to their testing equipment, the battery is ok, however low on crancking amps.
It is rated at 730 CCA but reads 589 CCA. I was told to charge the battery.
I haven't had any problems starting the car but the radio still works when it wants to.
The alternator gauge shows about 14 volts.
the battery is Interstate, but does not have the date punched in (stickers removed). Do you think I should go ahead and change the battery?
One more issue has come up. The tire monitor displays is beeping. It displays the pressure on all 4 tires in the normal range, yet it beeps and I could not reset it.
Do you think this would be caused by the battery?
Thank you for any advice you gentlemen can provide.
RG
RNajarian 01-28-2020 06:04 PM
The battery is at or near itís expiration date. Since it is already out of the truck I say replace it.
How old are your TPMS batteries? Usually they are only good for 7-8 years. I have a trusted mechanic who does tires. I would have him check out the sensors.
Raulg 01-28-2020 09:17 PM
RNajarian,
I re-installed the car battery because the test indicated it was still good.
I can remove it and get a new one. I hope that takes care of the issues.
In regards to the tire sensors, I didn't know the batteries are replaceable.
I thought the sensors were sealed.
Where would I find out what the replacements types / part numbers are?
Thank you
RG
RNajarian 01-28-2020 10:13 PM
Unfortunately the entire TPMS sensor needs to be replaced . . . Some good tire shops can source good replacements for $70, the OEM ones are about ~$150 each if memory serves me right. The frequency of the sensors changed at some point, but the Tire shop can look that info up, or I wonder if the Pelican Parts part Looker Upper feature would give you the info.
Raulg 02-07-2020 10:20 AM
RNajarian,
I haven't changed the battery yet. I had to travel for work.
I will get a new battery this weekend.
I wanted to mentioned that I noticed that the clock is also acting strange.
If the time is reset, it keeps time as long as the car is running. If I turn it off and turn it back on sometime later, the time is off by an hour or so.
I was able to reset the radio temporarily. It operated for a short while and then it went back to turning itself on and off. I also noticed that the display on the radio is in german now and will not reset to English.
Any words of wisdom?
Thank you
Raul
RNajarian 02-08-2020 07:51 PM
Hmmmm . . . that’s a tough one. A lot of electrical Gremlins.
Is there a clogged drain hole leaking water into the cabin?
From my experience I can say that twice I’ve had crazy electrical gremlins that were resolved by replacing the battery.
Maybe you can try this ... Put the battery on an overnight charger then start it up in the morning, does anything improve?
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
