-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/)
-   -   2006 Cayenne Turbo S (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/1088745-2006-cayenne-turbo-s.html)
PHillary 03-17-2021 03:06 PM
I am looking at a 2006 Cayenne Turbo S for purchase...The current owner says it drives but hesitates it will drive but not drive far before shutting off???
I guess my main question is how much of a headache is it to bring it back or is this something I should forget about it and run the opposite direction???
It's less than 5K for local pickup...Is this something worth grabbing up?
fintstone 03-18-2021 05:49 PM
Those are great cars, but whether or not it is fixable is hard to say form what little we know. Might need an engine or just a coil pack. If an engine, that is more than the car is worth and you will probably sell for parts.
island911 03-19-2021 07:55 AM
Sounds like a fuel pump dying.
See: https://forums.pelicanparts.com/porsche-cayenne-macan-forum/862745-955-turbo-starts-fine-stalls-dies-after-2-3-secs.html
PHillary 03-19-2021 11:14 AM
Thanks for the input...I am going to see the car in person tomorrow so I will let you guys know what I think...
fintstone 03-19-2021 07:34 PM
Originally Posted by island911 (Post 11265750)
My first thought as well. Puling the fuse for the primary kept me from not getting home a couple of times before I fixed my fuel pump. The 2006 S was the higher HP version. This could be a good truck. As my 2004 TT gets more and more miles, I would jump on the right relatively low mileage turbo.
PHillary 03-22-2021 12:03 PM
So! I ended up not buying the Turbo version...It had too many problems for my baby budget to start with...I found a nice 06 "S" model that just needs some TLC for now. Thanks all for helping me make an educated purchase on this thing.
http://forums.pelicanparts.com/uploa...1616439526.jpg
http://forums.pelicanparts.com/uploa...1616439526.JPG
PHillary 03-22-2021 12:06 PM
NOW! What are some of the things I should be doing first off...I am going to do a oil change real soon maybe this weekend coming...
Thanks all
fintstone 03-22-2021 12:29 PM
Great looking vehicle.
I don't fix anything on mine that isn't broken. It is smart and will generally tell you (with codes/check engine) when it is. Typical issues are fuel pumps, coolant leaks, coil packs and the driveshaft bearing carrier. It is heavy and will need tires fairly often and brakes if you are not gentle on them (but a sensor will tell you when the brakes are worn). Change the oil.
PHillary 03-23-2021 06:49 AM
So...Just yesterday after work...the check engine light came on??? Uh Oh? Right! I've had the car for two days! Boy my luck...Lol! So, I went into Advance used their checker to see the codes and P2189 came up...According to the reader it is running too lean??? and it said if I had drivability issues to stop driving it??? The problem is the car drives fine??? I actually drove it from New Port Richey FL to Lakeland FL about 70 miles on Sunday then back and forth to work these last two days...The car drives fine but the light is on??? So far I filled the tank and added two 16oz bottles of seafoam in it since the light came on...I have not done anything else but that...I think I should drop it off at my local mechanic who works on my 944 to see what he thinks of it and if I should keep it or just give it back to the place where I brought it from??? Ugh!!!
fintstone 03-23-2021 08:43 AM
It does not sound horrible...but nothing is cheap to fix on these. Sometimes it takes a while to find a leak/problem...so troubleshooting time adds up. It sound like you have a leak (air) somewhere and are running lean because of it. Seafoam will not help. You need to find the leak. Check intakes/hoses/MAF to see if they are light/in good repair.
If you just googled up the fault, you need to be more specific and add "cayenne" to your search...as these cars are often a bit unique.
You may be able to get the seller to fix, but they probably just cleared the fault to sell it to you (and knew about it)...so, I doubt it. A decent P-car wrench should be able to fix and reset the fault.
PHillary 03-23-2021 08:52 AM
Yep! That was my first thought that they cleared the code for it to sell they did not anticipate me driving it 70miles back home giving the computer enough time to re-diagnose itself and coming up with the fault again...I already knew because of the nature of the beast I would be fixing it...I called them today and went over this with them he says that they serviced the serpentine belt and changed the alternator to it and never saw the engine light come on...I doubt this but giving them the benefit of the doubt...I will have it looked at by my guy and see what's going on with it...hopefully you all are right and it not much to fix and maybe it is minor...it is always possible a hose could of came loose or has a crack causing to run lean...thanks again for the feedback and suggestions.
fintstone 03-23-2021 09:19 AM
I would guess that they did not seal a hose correctly when they put it back together. It doesn't take much of a leak.
I had a leak a few years back before I started working on mine much. It took my independent wrench several hours of labor to find it. Sometimes air leaks are tricky.
PHillary 03-23-2021 07:51 PM
The mechanic was not in today so tomorrow?
Is there a PET for our cars like they have for the 944???
fintstone 03-23-2021 08:33 PM
Yes. I downloaded one from this link:
https://www.porsche.com/all/media/pdf/originalparts/en/E_9PA_KATALOG.pdf
PHillary 03-23-2021 09:37 PM
Cool I am starting to sense this thing doesn’t have blue tooth??? It has phone features I think but there’s doesn’t seem to be a usb port into the network of the car
honerboys 03-24-2021 08:51 AM
usb in center console...maybe?
PHillary 03-24-2021 10:23 AM
Thanks will give it a look-see! I doubt it though...Lol! but I will check.
fintstone 03-24-2021 10:36 AM
2006 is probably too old for that. My 2004 does not have USB or blue tooth (despite being fully optioned).
PHillary 03-24-2021 02:03 PM
What did you do? Did you just buy a Bluetooth device that Highjacks the radio frequency?
fintstone 03-25-2021 08:37 AM
I don't. Just listen to the radio or a CD.
honerboys 03-25-2021 08:50 AM
no aux input either? - my son's 2007 ford fusion has one of those - on my 2012 both the aux input and usb are in center console box
PHillary 03-25-2021 03:07 PM
I doubt it have not seen on of those unless its in the rear console somewhere but I doubt it since there isn’t one upfront....Lol!
I ordered a cheap $20 cigarette lighter Bluetooth device that high jacks the radio and plays your phone music it also has usb charging ports....Problem solved!!!
The thing so proper it doesn’t recognize mp3 files I put on a CD so I have to make a standard 14 song dics....SMH so Porsche like...Lol!
Aurel 03-28-2021 04:38 PM
Those older Cayennes often have the headlights lense fogged and yellowed. I had a similar issue on my 2008, and found a $15 3M kit that works wonders to restore them. It includes an attachment for your electric drill, all the abrasives needed, and a clear coat that really brings them to as new condition. It is a very satisfactory job to do, with very rewarding results.
https://www.google.com/shopping/product/6266363928376565251?q=3m+lens+restoration+kit&clie nt=safari&hl=en-us&sxsrf=ALeKk011rfBCCmM25FSaVM9CDHe9lFMccQ:161697 4602565&biw=1292&bih=839&prds=eto:1115507257105841 7204_0&sa=X&ved=0ahUKEwjfvLXuk9TvAhUNMlkFHdMCCDIQ8 gIIowU
Gianni at Pelican Parts 04-02-2021 02:52 PM
It definitely isn't a bad idea to keep a bookmark of the Cayenne Tech Articles on your browser.
PHillary 04-05-2021 10:08 AM
Fluid Change
Hey guys I have been hearing that the diff fluids need to be changed on a car with this type of mileage...What are ya'll thoughts on this? Also what else should I be looking out for on this thing?
