Cam sensor engine light 2004 Cayenne S
My engine light (for cam sensor) on my 2004 Cayenne S keeps/stays on after the sensors have been replaced.The shop now thinks its a problem with the cam but I'm not sure they are truly on top of it because they said initially that it was just a sensor issue. Surely the diagnostic check would differentiate between a true sensor problem vs. a cam problem.
Can anyone enlighten me on this issue? Thank you. Roger |
What was the code? Did they clear it with PWIS after replacing the part? Did they replace the sensors on both banks?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
