Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Buccaneer of the tarmac
monovich's Avatar
2009 Cayenne GTS: PS pump or Tandem pump?
I just added an '09 GTS to the fleet a couple of weeks ago and I have a list of to-do items from the PPI. I'm not a hugely experienced home mechanic but forums + youtube have helped me up my game bit by bit. Part of the premise of owning this vehicle is that I work on it so that I can keep upkeep affordable.
I'm trying to sort out course of action on this item from the inspection:
power steering fl uid very dark and pump whines at all rpms
I can confirm that it whines at all RPMS. Very annoying. First thing I did was Youtube the basic flush and performed a flush, albeit with the PS fluid recommended by O'reilly not the CHF 202. This did not fix the whine at all. Did the 5x full steering turn lock-to-lock. No bubbles, etc. I DID notice that the 2nd reservoir for PCCD was quite low, so I topped that off. But now I'm wondering if I should just re-flush both systems...
Bigger issue: Should I just replace the PS pump entirely? That is what I was assuming I should do, and it looks sort of do-able DIY based on the videos I've watched and the Porsche Service manual that I read. The pump looks to be about $500-700 and the fluid $40. But I also had a local shop quote me for the work and they quoted an eye popping $3500. What gives? I looked at the breakdown and they list $2500 for the pump. So I asked them about it and they said I need the tandem PS / PDCC pump 958-314-022-11 and that is unobtanium until at least some time in May, and it's expensive. When I put the model into parts searches here and FCP I come up with other pumps. like this one, which says not for use with PDCC models: 95531405011
Pelican has this: https://www.pelicanparts.com/More_Info/95831402211.htm?pn=95831402211&SVSVSI=&KeepHeader=Y&ByPassCat=Y
So my outstanding questions are:
1. Is it obvious I should replace the entire PS pump or should I try something else (like a reflush of both systems with CHF202)
2. Is the $$$ pump the only pump that works?
3. I see no system leaks or drips under the car. The PS system was not low when I got it, PCDD was.
Any help would be appreciated. In the meantime I'm off to replace plugs and ignition coils.
edit: Also found this third party pump:
Power Steering Pump - 2008-2009 Porsche Cayenne - A1 Cardone W0133-1804144
Review Fitment Notes
Part Number: W0133-1804144
Brand: A1 Cardone
Notes: Remanufactured -- Models w/Front & Rear Anti-Roll Bars w/Active Body Control (PDCC)
'76 912E
'91 E30 M3 Evo 2
'09 957 GTS
Old 04-22-2023, 11:55 AM
honerboys's Avatar
hey monovich - cars with PDCC have the tandem pump - the chassis control and power steering are 2 separate systems but use the same pump - the tandem pump has 2 separate pumping chambers inside it - so it will cost more than the pump for cars without PDCC - now how much more i don't know - there may be after market pumps available - depends on whether you are a porsche purist who would not put a non porsche part in his car or not - that said, make sure the whine is actually the pump itself and not the lines to either the PS or PDCC - here's a link to a thread i started on rennlist - my car (and a lot of others) whines but it doesn't seem to be coming from the pump - more like it's in the lines - there seems to be no definitive fix - i don't have PDCC but some people have quieted some of the noise by re-attaching a PDCC line up front - check out the thread
https://rennlist.com/forums/cayenne-958-2011-2018/1242124-whining-noise-from-what.html
84 928 S - SOLD
2012 Cayenne S
Old 04-22-2023, 02:38 PM
monovich's Avatar
Thanks for the direction to that thread. Fascinating. I just changed the oil today and noticed that the cooling line is not attached at all. Buying some of the anti vibration mounts and trying that next.
'76 912E
'91 E30 M3 Evo 2
'09 957 GTS
Old 04-22-2023, 04:20 PM
honerboys's Avatar
good place to start - let us know if that solves your problem - and also post the results on rennlist so those people will also know - thanks
84 928 S - SOLD
2012 Cayenne S
Old 04-22-2023, 07:09 PM
monovich's Avatar
Which forum gets more traffic these days? This or Renn?
'76 912E
'91 E30 M3 Evo 2
'09 957 GTS
Old 04-23-2023, 08:40 AM
honerboys's Avatar
i think there are more people on rennlist than pelican - that said, there are people on here that are not on rennlist so i follow both - lots of car knowledge on both sites
84 928 S - SOLD
2012 Cayenne S
Old 04-23-2023, 06:52 PM
