Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
It'll be legen-waitforit
stealthn's Avatar
2012 Cayenne S (v8) plug gap?
The internet is all over the place on this, what is the spark plug gap for a 2012 Cayenne S V8?
Thanks in advance
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 06-28-2024, 07:55 AM
stealthn's Avatar
Never mind, the plugs are 4 posters so no need to worry about gap.
Just did plugs and coils and damnit one of the coil screws snapped in the threads. I am not sure if I should try to drill it out or something else. Pretty pissed…
Thoughts
Bob James
18 Macan GTS
Old 06-29-2024, 01:36 PM
honerboys's Avatar
a lot of times you can just back the broken piece out with a screwdriver or sharp pick - they are not in there tight and being aluminum are easy to dig into
84 928 S - SOLD
2012 Cayenne S
Old 06-29-2024, 04:16 PM
stealthn's Avatar
Thanks, turned into a pain in the arse, with great joy
It was just under flush with the head so I couldn’t cut a grove into it.
So I drilled into it, then tried my removal bit, to no luck
Then I got the great idea I would sacrifice my smallest bit (13 splines I think, not sure what it’s called). Hammered it into the hole and was able to turn it out
Got her all buttoned up and gave it back to a happy wife
Bob James
18 Macan GTS
Old 07-04-2024, 03:14 PM
honerboys's Avatar
i tighten those down with my fingers and that's it - they probably get a little tighter when i put the trim screws into them but they are usually pretty easy to remove that way - dumb design
84 928 S - SOLD
2012 Cayenne S
Old 07-05-2024, 07:01 AM
