Intermittent Suspension faults
Over the last few days I have been getting Suspension faults on my Macan. They would flash up twice then go away, not to be seen again. The interesting thing is it drops the Macan out of Sport mode.
I can put Sport back on again after but it's strange. It's starting to get colder so not sure if that's it, or if it's battery aging, but it seems to always be charged fine. Thoughts? |
Intermittent suspension faults on the Macan, especially when it’s cold are often caused by a weak battery or a sensor starting to fail.
Yeah not sure of the sensor as it drops it out of Sport mode too. The battery shows good voltage too. Surprisingly it was considerably colder today with a foot of snow and no warning. I also hooked up my scanner and no codes.
Update: Drove it about 20 times since the warning, in both cold, warmer, wet, etc. No error. Man these sensors are sure snowflakes :D
My 2005 Cayenne does this in the cold. I suspect the actuator that puts it into low range is failing.
| All times are GMT -8. The time now is 07:34 AM. |
