-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/)
-   -   How to Remove Taillight Assy? (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/634406-how-remove-taillight-assy.html)
BoxsterGT 10-12-2011 01:53 PM
How do I remove the Taillight assy in my Cayenne?
I have taken out the (2) screws, but something else is holding it in.
Any clips that must be pushed in to release it? Don't want to break an expensive part.
Thanks in advance!
Len
914-6Porsche 10-12-2011 03:55 PM
There are two ball type pop in type thingies holding mainly the other side. If you have never, or if it never has been out before you will probably break the damn things. You can either opt to get some new ones now before you take it out, for when you put it back in, or you can just say the hell with them. I have been running mine for a couple years without them. The two bolts will hold it in unless you have a 10G crash in reverse. You need to have something soft to pry the outside of the light away from the body and it will pop right out. I have purchased the replacement pop in nut things but have never had the time to do it. Good Luck! It is really a ridiculous setup for such a great truck.
Mark
____________________________________
Original Owner 1970 914-6 #397
2004 Cayenne Turbo
2006 Cayenne S
914-6Porsche 10-12-2011 04:01 PM
I forgot, the two plastic nut things are probably under 3 bucks.
Mark
BoxsterGT 10-13-2011 05:30 AM
SmileWavy
Thank you Mark.
Will try this tonight after I order the retainers.
Len
