-   Porsche Cayenne & Macan Forum (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/)
-   -   here we go.. (http://forums.pelicanparts.com/porsche-cayenne-macan-forum/708362-here-we-go.html)
yaya97 09-26-2012 09:23 AM
here we go..
Dear Pelicans,
I am in the market for a 2004-2005 Porsche cayenne S ( no v6 or turbo).
I have a long history with 911`s but 2 kids and a wife ...in a 911? no!
I think that for 17-18K the Cayenne S sounds great.
I know the number one concern are the coolant pipes. I would not consider one without the alloy exchange. I also know that some tires burn fast and that an oil change is a nightmare but I am not at all a lead foot and my local mechanic would be able to suck out the oil for the change.
Gas mileage? I imagine maybe 19 highway as I am a light foot ? I do not believe the dealer that said he gets 22 driving at 65... but I do not expect 11mpg either.
I know some cayennes burn oil and some not... No idea why?
What else besides going over the maintenance records should I look for? The cars I have been looking at have under 80K miles.
Any feedback you greatly be appreciated!!!
Richard
yaya97 09-26-2012 01:46 PM
Nobody???
Fixer 09-26-2012 02:58 PM
Richard,
I had a 2004 S and sold it and miss it much.
They are great Trucks and do get about 22-26 mpg at 55-65mph. I always cruised mine slow but they do go..
You will get 14.5 mpg city though.
They are great, i would get a 2005, the 04s like mine had loud hvac flaps, but that was worked out.
They have no mechanical issues other than the plastic coolant pipes degrading (world-car manufacturing, there can be issues like these) , ( I replaced mine with aluminum units myself)
Find one that had more frequent oil changes (5-6k miles) the ethanol is really bad for motors and they really shouldn't go 10k btwn changes.
Porsche techs say the ethanol washes out the cylinder walls with infrequent oil changing. Thanks Al Gore.
Changing the oil is tricky the first time but becomes second nature and you get to marvel at the engineering in that Porsche truck from below.
I really miss mine but it had to go for space/use reasons.The guy that bought it still e-mails me once in a while to say hi.
Good luck with your search, take your time there are plenty out there.
fintstone 09-26-2012 04:59 PM
Why are you not considering the Turbo? The difference in acceleration and braking is night and day?
yaya97 09-27-2012 05:57 AM
Thanks so much for the responses!The turbo would just be overkill for my use
ninelevenick 09-27-2012 06:04 AM
Hey yaya,
Fixer's response is thoughtful and on the mark. A Cayenne S at cruising speed will get better mileage than what the EPA claims. It's an amazing vehicle, and it will haul your family of four with ease.
yaya97 09-27-2012 09:54 AM
thanks to all! I will report when i find THE car!
island911 09-27-2012 11:35 AM
Braking? Red paint on the same calipers?:cool:
ah, the PASM, I'll bet. fwiw, my 955S also has the PASM system. (I looked high and low to find that on an S) ...I haven't tested threshold braking on the non-PASM equipped, but I have been impressed with fast response of (stiffening) the suspension on panic stops.
BTW, I went with the non-turbo because the turbo eats too often (fill ups, brake pads, tires, oil) Sure, the S is no Prius, but better.
fintstone 09-28-2012 01:11 PM
But, but, but....I love the red paint.
island911 09-28-2012 04:53 PM
:D
Come to think of it, I'm not sure that mine doesn't also have optional turbo brakes (in silver) or if they came standard. I know that 18" wheels are the smallest that will fit over the front calipers. ...and yet some Cayennes have 17" wheels a standard. (maybe just for the 6 cyl ?)
yaya97 10-02-2012 05:53 AM
Besides HVAC potential noise , is there any difference between an 04 and an 05?
fintstone 10-02-2012 06:34 AM
Supposedly the Cayenne Turbo and S have the same caliper except for color (silver vs red) and both have 350 mm rotors. The base model has a smaller black caliper (black) and a 330 mm front rotor. The red Turbo S calipers are still larger and the front rotor is 380 mm.
Supposedly, the rear units are the same size for all.
island911 10-03-2012 09:40 AM
Thanks fin.
yaya97 Besides HVAC potential noise? --I haven't heard about that.
yaya97 10-05-2012 06:31 AM
I found an add of a dealer selling a gold 2004 S with 77K miles for $16K. Perfect on paper
but
The dealer assured me over the phone that the coolant pipes were changed at 45K miles. When I got there, I asked for documents the dealer said oh it was just a verbal confirmation by a Porsche dealer but the invoice ( as well as all the maintenance records) was..lost!
Then I went to look at the car. First thing I noticed was the fog in the headlights... Maybe hit and badly replaced? Or maybe nothing. THEN came in my mind the dealbreaker : In the center of the drivers door were a few 1 inch rust bubbles popping out from under the paint. Is this normal for a Cayenne to have rust bubbles? I declined the test drive and drove back home. Was I right??
fintstone 10-05-2012 10:58 PM
My 2004 has no rust nor is there anything wrong with the headlights. I am not sure I could find documents showing coolant pipes were replaced...but most were if the car was serviced by the dealer...as most high-dollar cars are when new.
island911 10-06-2012 06:03 PM
fog in the headlights: a small crack will let water in, and then it has no where to go.
It is possible to visually inspect for the metal lines, but Rust!? :eek: ...no wonder the price is so low.
yaya97 10-07-2012 01:16 PM
thanks to all! I will keep looking
yaya97 10-09-2012 05:05 PM
found another 2004 s . Looks greaton photo BUT has no sun roof... not a dealbreaker if the rest is good! finger crossed!
ninelevenick 10-09-2012 11:14 PM
Wow, I assumed all Cayennes came with a sunroof. I hope it turns out to be the one for you, Yaya.
Scott R 10-10-2012 01:40 PM
I've had a tough few months with my 05'
1. Rear convenience module replaced (third time, second with the updated part)
2. Wiper arm on drivers side came off
3. Filler tube gasket for the washer tank broke - this turned out to be a MAJOR repair
4. Drivers side turbo to inter-cooler pipe leaking oil on my floor
5. Rear hatch door handle broke off - also a MAJOR repair
6. Instrument cluster failure (failure of the speaker in the cluster)
7. AC - documented here but was an epic journey to repair
8. Radio INOP issue on occasion - fixed with new fiber optic cable, woo hoo!
On the flip side, I have no odd tire wear that a lot of people report, and my brakes are measuring good after each service. I'm also on the original coolant pipes with no issue as well, granted I'm only around 35k though.
I have one outstanding issue that's getting annoying, "suspension fault" :( I need to catch this while it's on and drive it into the shop since it's not logging a code. Dealer suspects the pump might be dying.
Still a fun car.
fintstone 10-10-2012 04:53 PM
There is a sunroof in all my cars except for the targas. Never use any of them.
fintstone 10-10-2012 05:00 PM
Originally Posted by Scott R (Post 7023722)
I've had a tough few months with my 05'...
Same here with my '04. The cruise stopped working, but it was a surprisingly cheap easy fix (brake switch).
Replaced the battery (what a pain in the butt and I had to drive 2 hours to get the right one).
Now one of my cornering lights is out (H3). I guess that will wait for the weekend.
Looks like the front brake pads will need replacing soon. Any of you guys do that yet? Painful?
yaya97 10-11-2012 07:58 AM
Tested the car yesterday and found it beautiful. Maintained at a Porsche dealer for 6.5 years but at 88K miles I found out that the coolant pipes HAVE not been changed... thus I asked the dealer to do the change if I buy the car.... will see
Fixer 10-11-2012 03:32 PM
Make absolutely sure the coolant pipes were updated. Trust but verify.
I did mine and it was expensive and took me 9 hours. Not pleasant.
Auto atlanta sold me the kit cheap for $550. dealer wanted like $900.
When you guys start to have electrical glitches, look into your battery condition.
I used to disconnect and reconnect and little annoyances would go away.
I would also be sure that the P.O. changed the oil frequently and not every 10k miles due to ethanol blended fuels. 7k miles is the max i would go btwn changes. Porsche techs warn of ethanol washing out the cylinder walls leading to premature wear. Techs have also told me Cayennes are very well built and reliable with no real issues except coolant pipes which were made by a supplier outside Germany. The plastic degrades, (world car manufacture issue)
Take your time and get one with a sunroof, the sunroof is nice in a Cayenne, they made enough to get the perfect Cayenne S.
Good Luck,
Scott R 10-11-2012 04:35 PM
Replacing the battery was two weeks ago when the computer would lose the convenience settings overnight. Meaning that my settings for the way the doors unlock, and the horn for alarm would all default. New battery and all is well!
yaya97 10-11-2012 05:11 PM
Good Luck,
The Cayenne am looking has been mainained all its life at a Porsche ONLY dealer. I negociated with the dealer to include the pipes with install... he agreed verbally. might be a Cayenne owner tomorrow ( BTW plse excuse my question but what does P!G mean?????)
yaya97 10-12-2012 05:31 PM
talk about crazy... I agreed with the selling dealer to purchase the Cayenne and he was to do the pipe change...then I was reading this morning the carfax and wondered why the car was maintained at 2 differerent Porsche dealers.... I already called the first one who said the pipes were not changed so I said heck, I will call the second porsche dealer.... The service guy was super nice and when I gave him the VIN he said oh "it had a coolant leak at 59000 miles so we replaced the entire system with alloy parts"......so I called back the seller dealer and deducted the 800 for the pipe job ( we had agreed on the this price). You would think that Porsche would have a common database between dealers!
MysticLlama 10-13-2012 01:58 PM
No sunroof isn't a bad thing. Ours still has the headliner out because of constant leak issues that we're waiting to verify are finally fixed we hope. Noticed this time when we took the whole assembly out that there was a mismatched bolt, so this has been a problem since even before we bought it.
yaya97 10-16-2012 07:09 AM
While cruising at 65 ... 22.8 mpg!! Crazy . I love this car!
