Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Brake Pads 2011 Cayenne Diesel
Can anyone offer advice on procedure for brake pad change on a 2011 cayenne Diesel. The caliper design does not allow for removal and replacement of pads through the top of the caliper as is usually the case with Porsche brakes.
Old 09-01-2013, 02:02 AM
That is because you need to remove the two bolts that hold the caliper in position.
Then you can remove the pads and compress the pistons to install the new ones.
To remove the bolts you need a triple square socket, i think that is the name.
Sorry for my english, im from Mexico!
Old 09-04-2013, 05:24 PM
