Hi i have a 08 Cayenne GTS CEL FLASHING with code P3080 cylinder 8 misfire. Power loss and vibration from the start. coil and spark plug maf sensor already changed. compression test for cylinder 8 is 16Bar about 232psi. porsche said the fuel system is fine. if i want to know more. i need to pay 1300euros for the diagnostic. need some help. many thanks
http://www.pelicanparts.com/more_inf...3974-23764.jpg __________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Cayenne Camshaft Position Sensor Replacement | 2003-2008 | Pelican Parts DIY Maintenance Article |
That compression number seems too high, perhaps you have a cylinder that is full of oil or fuel?
- Casey |
Swap fuel injectors around and if it changes
