Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche Cayenne
Porsche Cayenne 05
Hi ! I have Porsche Cayenne 05 I'm having a problem, PSM, PHC and Four Wheel Drive System Failure every 15-20 minutes while driving. When engine is off, message disappears and comes again when I start driving again. Battery changed. Still no help. Anyone know of this issue?
Old 04-02-2017, 03:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
How many miles on it? Is it shifting properly through the gears?
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 04-04-2017, 04:31 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
I got 104,000 miles. No problem with shifting and running. THX
Old 04-04-2017, 08:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Cayenne electrical problems
I'm having something similar, and I've done a lot of reading to see if I can fix it without getting raped at the local Porsche dealership. A lot of DIYers have found that water has gotten into the car and under the carpet due to clogged drains, and causes corrosion on wires that run under the carpet to the area where the battery is under the driver's seat. I don't have the link, but it's easy to check by pulling the carpet up and looking. Unfortunately for me, I guess, is that my floor was dry and I couldn't find any corrosion. I understand the Porsche makes a repair kit for the problem, although I can't find it anywhere. I was going to call Pelican Parts Monday and see of they could help. It sounds like a simple fix, if that's your problem, so good luck
Old 04-22-2017, 09:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Send a message via AIM to fintstone
Sounds like you are just driving on really crappy roads...or have a tire that is more worn that the others (or out of balance).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 11-02-2017, 12:55 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
