Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche Cayenne
no alarm if lights left on...2008 Cayenne
There should be an alarm if I leave my lights on, and leave my Cayenne taking my key with me.
There should be an alarm if i forget and leave my key in the ignition switch
I need to fix this!
Is there a switch in driver's door that has failed? Where is it located? I feel silly. I've looked and looked
Have you fixed this? What did you do?
Dave
Old 04-20-2017, 03:50 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
cfries's Avatar
I have the same issue. I think it may be a switch on the door but I do not see one. It has to be there somewhere, maybe a magnet switch or something. My interior light/door chime doesn't come on when opening the door so multiple things linked and the common denominator is a door switch.
61 VW Karmann Ghia
63 European Bug
75 Carrera Coupe 2.8L #81
75 911 Targa
2006 Cayenne S Titanium
Old 04-21-2017, 09:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thank you. if i open the rear door, driver's side the dome light comes on.
DaveL
Old 04-30-2017, 02:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
If I understand correctly you don't hear any buzzer if you leave your lights on? How about leaving lights on and pull out the key from the switch, you should hear a buzzer. Also, with the car off and no key in the ignition switch, turn your turn signal either way (left/right). If you are not getting any buzzer at all then it's your buzzer inside your display cluster that is bad.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 05-01-2017, 12:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
There is a switch in the door latch assembly. The mechanic took the door panel off. However, he didn't know the switch was in the latch
Old 06-06-2017, 11:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Fix is coming. I've gone to a different mechanic who diagnosed the problem quickly.
The switch is in the door latch assembly, inside the door in line with the door handle/lock. A latch is on order.
Old 06-15-2017, 04:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright 2016 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
