-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   A 944 diesel wait what ! (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/1044252-944-diesel-wait-what.html)
tims944 12-21-2022 06:15 PM
Hey so i finally tore it down,
its a long story that i didnt write here lots of **** happened in ohio before motor went but i did finally tear it down about 2 weeks ago picking up the spare motor tomorrow that im stealing the head from
basically all 8 valves are bent, # 2 intake lifter blew right out, top came off chunk out of head(mounting block for cover) and cam some nasty chunks...= head trash not worth fixing it had like 360k i put another 5k...
new used motor only has 160k km so im tearing it down will sell all the good stuff i dont need. if looks good as is will just put the new cam, bearings etc. lifters etc.
if lots of carbon build up if not will send out to be cleaned redone etc than bolt it on !
slowly and surely.
and honestly im not worried about motor for the 28psi.
the clutch i was using is/was not designed for a diesel, im currently working on an alternate plan maybe use the sachs SRE setup with a 968 HD disk or something unsure but those are tried and tested
i have basically had my fun racing it once and know those downshifts blew it to smithereans!
until next update !
tims944 06-22-2023 07:17 PM
she is back to life !! just havent had spare time to tinker on her, break in new cam and such and work out any new kinks.
wema780 07-14-2023 03:37 AM
So now we have an engine Platform. and a cut up gearbox to work out with as a bellhousing.
EhisAhiga 07-20-2023 01:21 AM
youd be surprised but there arent that many or at least not that many that fit my bill..
tims944 07-29-2023 09:32 PM
Huh ??.. above..
tims944 07-29-2023 09:34 PM
Happy to report she is running okay. Maybe a few bugs to work out.
But I finally manage to fit the hitch back onto this car. I had made it for another of my 944s but adapted it to my s2. After all. This thing definitely doesn't lack the power to pull my small 4x8 aluminum trailer.
Made a custom plug and play wiring harness!
Finally spent thr time and modified a spare fuel neck. No more adaptor needed ! Hallujah for fill ups.
Ifal goes well she'll be driving back to 944fest this september
tims944 01-21-2024 08:25 PM
unbelievably it broke down on the drive home from 944 fest again... UNREAL!!
this time while puling the trailer out of nowhere.
and verdic was... i sheered the clutch center out of the disk lol..
anyway i finally pulled the trigger on the Fancy A** Clutch
Audi Sachs SRE kit
240 MM DMF designed for TDI
968 turbo clutch disk(solid hub)
Sachs SRE PP.
and well see how she goes, currently hibernating!
OPRN 02-17-2024 08:16 PM
I just stumbled on to this thread. Great swap! When I bought my first 944 the fellow had a 924 as well with a bad engine. I could have bought it for very little and regret not doing so. I too am a huge fan of the TDIs and have 2 spare engines at the moment. I have been dreaming about a TDI swap for several years now. That 924 would have been perfect!
My present '83 944 runs far too good to cut up so perhaps another without an engine will show up in the future. Thanks for the inspiration!
tims944 02-25-2024 12:51 PM
I actually haven't cut up this car at all in that aspect. It's a custom front crossmember. Custom trans. Everything could easily be reverted on this car back to a stock s2. My plan all along if s2 values ever hit a real money worthy #.
But yea it was cheaper than a proper rebuild on the disassembled s2 motor. Though that was years ago. I'd probably ly slap in a spare one I have or a 968 motor. Who knows. But best of luck if you ever go down the road.
tims944 09-04-2024 07:47 PM
continues to amaze!
Happy to post car finally performed flawlessly on its way to and from 944fest 2024. and i even added a custom ac setup this spring!!
go me !
tims944 11-06-2024 05:43 PM
Proud to say I hit 10k km on the swap this week. This isn't really my daily driven car as we have 2 basically babies. So doesn't work for pickup or drop off. Only get to use when no kids!
On to the next 10k!
tims944 06-24-2025 09:02 PM
im happy to report, now on my 5th clutch disk lol.. setup..
running the luk 240 dmf
sachs peformance volvo clutch disk :P
sachs performance audi PP.
sachs performance audi TOB.
just swapped in the new tob, and disk.
no more clutch slip, 1 solid disk, no springs. material is rivetted to the disk itself.
have a spare gearbox with taller gears and better ting gear 30/8. plan to swap a quaife LSD into. just for fun and a bit more fun while hauling.
she will be making the drive to VIR for 2025 944fest !!
tims944 06-28-2025 06:40 AM
Decided to splurge and buy another gearbox. Taller gears and bigger ring gear.
3.750 vs the 3.556 ratio.
Current box code is HCF. Swapping to an HCK
Will also be installing likely a quaiffe diff into it.
It's funny no retailers technically sell an lad off the shelf differential for the audi 01x diesel box but with careful research.
The diff is 100% identical to the like gen 2 boxster/cayman.
The 97-99 uses the smaller bearing or side cover but the 2000-2004 I believe is the same!
Diff part # borrowed from 1 another !
So the quaife 16 diff should drop right in.
I tried to find a used one for a while but have wince given up, so once I get this box opened up and give ir a good bill of health I'll pull the crown off the stock open diff. Order up a new quaiffe diff. Install new bearings. Reset the diff for backlash and preload and call it a day!!
Happy weekend folkshttp://forums.pelicanparts.com/uploa...1751118021.jpg
tims944 07-29-2025 07:40 PM
Quaife Diff is on the way!
also happy to report first big parts run from Montreal to Toronto and back in 1 day. met up with like 10 customers, to sell parts and pickup some wheels a buddy was storing for me.
man does she go smooth on the highway!http://forums.pelicanparts.com/uploa...1753843237.jpg
tims944 09-28-2025 07:15 PM
Happy to report she made it to and from VIR for 944fest 2025 without a hitch!
while towing still pull 30-40mpg/ not towing 45-50mpg ! what a toy :)
