Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
911tracker85's Avatar
I did understand you but my question may be the problem.
from what I understand the RH cradle bolts up to the engine supports at the rear of the car. I had thought it then bolted up to the gearbox mounts in the front. but it is sounding like the cradle expects the gearbox to get bolted to the stock trans mount?
just read GM is now selling a new version of the LS7, wet sump and 570hp crate motor.....
Bob Cox
84 928S, Ruby Red linen/brown interior - preferred DD
87 924S resurrect and gut and another track car...
86 944 turbo my new DE/track car.
78 930 clone project car.
Old 06-16-2020, 07:18 AM
VacantSky's Avatar
Iím following now, sorry my mistake! Yeah the cradle bolts to the stock engine mounts in the rear, but requires the use of the Porsche trans carrier. Maybe you saw MrRPJís build and his cradle like I initially did when researching this swap and thought it was the renegade one? (ď..76 with 993 GT2 Widebody..Ē)
Old 06-17-2020, 07:11 AM
hmmm....
Bob Cox
Old 06-18-2020, 05:24 AM
VacantSky's Avatar
Minor update, finished my wiring harness adventure. BMW fuse and relay panel installed successfully in the smugglers box along with the odyssey battery. All systems check out! All relays are updated to Bosch style for mass availability. The rear sensor wiring I pulled out by the starter along with the wire to the starter solenoid. Using a deutsch connector the oil press, oil light, ďoilĒ temp, and alternator exciter wires jump across a shorter route than before with the starter to alternator cable. Which coincidently is the remainder of my shortened battery cable, that worked out perfectly! Pretty sure I can fire it up currently, so I now have zero excuses to not cut the front tub for the radiator..! That will be coming up next.
The frunk looks so much better with the fuse panel relocated!
Old 06-27-2020, 04:46 PM
VacantSky's Avatar
In regards to the clutch cable for a shortened 930 trans, I believe it will use the pt number for a long bellhousing 78+ 930 so I have that on order (930-423-401-09).
The 76/77 cable is a no go (I have one) along with the 915 cable. That leaves this one left..!
Old 06-27-2020, 05:11 PM
Hi,
Any modification plans for the gear box to keep the revs down ?
Old 06-27-2020, 05:29 PM
VacantSky's Avatar
Originally Posted by dtakenname View Post
Hi,
Iím using a 930 4 speed, the gears are very tall. 3rd and 4th are both overdrive gears. Roughly about 2300 rpm at 70mph
Old 06-27-2020, 06:04 PM
when still planning to do the 3.3 turbo engine, the shop suggested I have the 930 4sp regeared. the wide ratios prevent keeping the turbo on a boil with the drop in rpm between gears. suggested I bring 2nd and 3rd in, and even 4th but that tends to get the cruising rpm high.
but with an LS and the wide torque range, no worries.
Bob Cox
Old 06-28-2020, 06:02 AM
Just an off topic question if you don't mind, do you think the gear box in the Normally Aspirated 997 is geared to not to rev too high if attached to LS engine?
Any info appreciated.
Thanks,
Old 06-28-2020, 10:23 AM
That corresponds exactly with what I've seen real-world with my shortened 930 LSD.
"Purists are the Karens of motorsports.
1972 Porsche 911 Outlaw - 400hp/930 transaxle/13" rear tires
F/A-18C/D, F-15C, F-35B/C
Old 06-28-2020, 10:51 AM
Cheers to all the ingenious people in here not too afraid to tackle something this complicated.
I love to read about them so keep up the good work and please keep us updated. Some of us are living vicariously through your stories.
Tony
Old 06-28-2020, 11:36 AM
VacantSky's Avatar
My thoughts exactly, the way the LS carries itís torque across pretty much the whole curve will make it very ďat homeĒ behind the 930 trans
Thanks,
I donít know what the 997 ratios or final drive are, but if you can find a similar gearing chart as what i posted but for those cars, or look up their cruising RPMís that will be your answer. An LS crankshaft (or any engine for that matter) will turn the same revolutions as the Porsche one behind that trans. Hope that helps!
Old 06-28-2020, 03:35 PM
Speed Metal Army General
Your going to love this thing! Nice work
Old 07-22-2020, 08:30 PM
VacantSky's Avatar
Well. I cut the hole.
This has been a slump for me, so hopefully this will get me back in gear to buttoning this thing up! The radiator looks more like an intercooler but itís capacity is a little larger than the C5 corvette. And this will be a stock LS1. To feed it using my RUF valance I purchased a used boxster center radiator duct. Itís almost the same dimensions as the rad Iím using, and itís mouth opening is the same size as the valance opening. With a little trimming and stretching with heat it should work a treat
So that will make sure the radiator is well fed, and a pair of fans will take care of the bumper to bumper and stop light airflow.
I think I figured out the clutch cable problem. The 930 uses a different clutch pedal arm/shaft. It sits at a different angle than the 915ís, and it NLA. So Iím figuring out a work around for that and will update when I can
-Kenny
Old 08-08-2020, 01:30 PM
where are you venting the air?
Bob Cox
Old 08-09-2020, 05:04 AM
VacantSky's Avatar
Iíll be making a shroud like the RSRís used behind a center mount oil cooler, but a little more exaggerated. Similar to this:
Old 08-09-2020, 08:43 AM
