-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   86 911 LS7 Slant Nose conversion LS427 570 (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/1056316-86-911-ls7-slant-nose-conversion-ls427-570-a.html)
Yan2947 05-12-2025 07:49 PM
Thanks! Worked on the trailing arms today. Took them off and begin cleaning them up.
http://forums.pelicanparts.com/uploa...1747103879.jpg
http://forums.pelicanparts.com/uploa...1747103773.jpg
http://forums.pelicanparts.com/uploa...1747103773.jpghttp://forums.pelicanparts.com/uploa...1747104450.jpg
Yan2947 06-15-2025 01:16 PM
Has anyone run a 1/2" fuel line for their engine swap? The LS 7 series motors are recommended to have 1/2 " fuel lines. Anyone put in 1/2" lines?
Yan2947 06-18-2025 07:09 PM
Cleaning, painting and reassembly
The slow process keeps moving ahead.
http://forums.pelicanparts.com/uploa...1750298653.JPG
http://forums.pelicanparts.com/uploa...1750298819.JPG
Cobalt964ruf 06-19-2025 07:26 PM
Wow, the red looks good
Yan2947 06-22-2025 05:52 PM
Roof re-do
Today we finished cutting the roof off. Sometimes you have to do things the second time to get it right. Sometimes you have to do it yourself or with friends who I wish I had done this originally.
http://forums.pelicanparts.com/uploa...1750639850.jpg
Cobalt964ruf 06-25-2025 03:24 AM
I’m running 6an fittings and lines.
Cobalt964ruf 06-25-2025 03:25 AM
Carbon fiber roof?
Cobalt964ruf 06-25-2025 03:27 AM
Trailing arms look good. Did you wire wheel them or chemical clean them?
Yan2947 06-25-2025 05:10 AM
Just wire wheel.
Cobalt964ruf 06-29-2025 10:05 PM
Originally Posted by Yan2947 (Post 12487165)
Just wire wheel.
Nice
Yan2947 07-22-2025 03:45 PM
Long day working on the fuel lines and then putting the front suspension and steering rack back on, followed by the gas tank. Those fuel lines are a pain in the butt to install, and there is no room for error. Last week I painted the front trunk area to clean it up a little.
http://forums.pelicanparts.com/uploa...1753224252.jpg
YellowBee69 07-22-2025 05:44 PM
Looking awesome!!
Yan2947 07-25-2025 09:38 AM
Wiring
Spent a good part of last couple weeks on wiring and finishing up all the burnt wires and making all the connections. I have a pretty good grasp on everything now I was hoping someone could help me out with this one last harness that I have a feeling I’m going to need as opposed to removing it. If I need it, I might just put a connection on it and then run it to where I need it anyone else tackle it is a photo of the eight wire harness that I originally cut from the other portion of the harness, I believe, probably went to the computer of the original car. here are the photos, one describing the harness, but perhaps someone could give me it in Laymans terms.
http://forums.pelicanparts.com/uploa...1753461377.jpg
http://forums.pelicanparts.com/uploa...1753461377.png
Yan2947 07-26-2025 12:31 PM
Getting ready to test Fit the motor maybe next week so I finally got it off It’s GM wooden Crate. Don’t know if anyone knows what alternator did you purchase for your LS? How much amperage did you decide to go with if you know and if you have your model number for your alternator that would be great thanks! Also, which oil pan did you get? My 89 has the flat one this one’s too big I think.
http://forums.pelicanparts.com/uploa...1753558196.jpg
Yan2947 08-27-2025 03:42 PM
I did a little test fit of the engine and tranny today. Want to see where all my wiring will lay out.
http://forums.pelicanparts.com/uploa...1756334494.jpg
MadMaks 09-04-2025 07:28 PM
This project looks awesome :eek:
That red pops like crazy. Definitely following.
Cobalt964ruf 09-05-2025 07:28 PM
Looks good
Yan2947 09-15-2025 01:57 PM
Have been working on the wiring for quite a while and finished installing a bulkhead connector from maven Performance. I am able to put the main ECU and the LS7’s fuse box on the floor behind the driver seat. This way I really keep the engine day much less cluttered.
http://forums.pelicanparts.com/uploa...1757969572.jpg
Yan2947 10-20-2025 08:21 AM
Front hood option for front radiator
What do you think of this option if I decide to put a radiator upfront? Similar venting that a GT3 RS might have. I would have to get rid of my gas tank and have the radiator flow up over the hood instead of underneath the car. Just a thought.
http://forums.pelicanparts.com/uploa...1760973534.jpg
Yan2947 10-20-2025 08:46 AM
If you are interested in the files, I purchased them from:
Cebotari3dwork@gmail.com
He has a facebook group and does amazing work. I have not printed anything out yet. I won’t be able to for about two more weeks.
http://forums.pelicanparts.com/uploa...1760975153.jpg
