-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   '07 Cayman 3.4L into an '03 Boxster S (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/1069533-07-cayman-3-4l-into-03-boxster-s.html)
klink 08-07-2020 09:05 AM
Motor has been in car running with an '07 Cayman motor harness adapted to the original 7.8 DME. DME has been reprogrammed. It would not smog. So starting over. I've installed an '06 Cayman S engine harness and I have a used 7.8 DME out of an '06 Cayman with it''s VIN #. I have searched high and low for the diagrams for the two chassis plugs in the motor harness so they can be adapted to the Boxster. I would appreciate any insight as to where I might find these. Thank you in advance!
Golten951 08-07-2020 01:58 PM
Contact Tims944 here on Pelican. he may be able to get you the wiring/plug diagrams. He has helped me a lot with diagrams.
klink 08-07-2020 03:24 PM
Thank you for that. I appreciate it!
