-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Using factory water cooled pipe on 1988 Carrera LS (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/1142168-using-factory-water-cooled-pipe-1988-carrera-ls.html)
1rad55 06-23-2023 07:50 PM
Has Anyone used the 996 or later factory radiator aluminum or stainless (?) tubes as part of their water cooling plumbing on factory air cooled bodies.
I was thinking instead of using Renegade Hybrids radiator hose from front radiator to rear engine..... I could incorporate some of the factory water cooled aluminum or ss parts. I build custom restomods LS radiator systems with ss pipe and silicone components which simplify the coolant components
Please advise and thanks in advance for your input to my question!
Yan2947 06-24-2023 06:27 AM
I think everyone has thought about that and thought of making custom pipes also. How would you get it under or through to the front?
MrRPJ 12-11-2023 07:35 PM
Yep i did the whole car in alloy hard line
